Finally got a moment to pare down Nick's damn near gigabyte movie to something I could post.
We started one motor, then the other (no divider required), then adjusted the second until the color was the same (within reason), then fine adjusted one until the beat frequency (sort of) went away.
Very finicky. I don't see how you could reliably run them in or out of phase without a fairly sophisticated closed loop approach.
Steve W's paired Lockies
- Steve w's paired lockies, small clip.wmv
- (1.99 MiB) Downloaded 1601 times
Re: Steve W's paired Lockies
Here's my rig (2 M15E motors), successfully fired yesterday. A coincidental effort, BTW.Mike Everman wrote: We started one motor, then the other (no divider required), then adjusted the second until the color was the same (within reason), then fine adjusted one until the beat frequency (sort of) went away.
Mine required a separator for startup. Lockup was quite noticeable, with ending of the asynchronous "beat" and a slight reduction in total sound level.
Slight reduction in power (qualitatively) was noted.
Slight change in one throttle setting disrupted the sync.
- M15E dual on stand v forum.JPG (63.19 KiB) Viewed 5291 times
re: Steve W's paired Lockies
great setup thnx for the video!
Cool, Bill! I didn't know you'd made two.
What would happen if both combustion chambers were connected with a small diameter pipe, say 3/4", I wonder if you could tune the length of the pipe to make them run in or out of phase?
Re: re: Steve W's paired Lockies
That's how Lockwood did it. Yes, you can tune the interaction by the length of the connector.James D wrote:What would happen if both combustion chambers were connected with a small diameter pipe, say 3/4", I wonder if you could tune the length of the pipe to make them run in or out of phase?
There's a power loss when you do this--I don't have the figure for how much.
