If you used a coper based water coil inside the engine the heat absorbtion would be greater, which might not be a bad thing depending on your goals. The greater the difference in temperature and the higher the conductivity the higher the rate of absorbtion would be.
Basically the stainless tailpipe will act like an insulator somewhat, and keep a lot of the thermal energy in the exhaust gas.
If you are going like Mikes approach with the steam rocket a coper internal coil might work very well.
I made a small, and very ugly engine out of tightly coiled brake line and furnace cement + headder wrap. The "wavy walls" made for most impressive heat absorbtion.
Water Injection
Re: re: Water Injection
thanks. Hey Simon, I'm going to be in Zurich in a couple of weeks, which way should I tip my glass?tufty wrote:Man, that's beautiful.Mike Everman wrote:Here's the art. Increasing surface area and extracting more heat with tail expansion are metrics to work out.
Simon
Southwestish. Zurich is a ways away, shame you're not going to be in Geneva...Mike Everman wrote:Thanks. Hey Simon, I'm going to be in Zurich in a couple of weeks, which way should I tip my glass?tufty wrote:Man, that's beautiful.Mike Everman wrote:Here's the art. Increasing surface area and extracting more heat with tail expansion are metrics to work out.
Simon
Have fun anyway, Swiss hospitality can be quite something.
Simon
Don't you mean swiss hostility? :P I thought swiss people didn't like any disturbance, especially not a noisy pulsejet. :Dtufty wrote:...Have fun anyway, Swiss hospitality can be quite something...
