Water Injection
re: Water Injection
OK, keep going and you'll end up with what I'm doing! ha
I'll just tell you.
The outer jacket will not work for a flight system because the pressure will crush the pjet unless it is quite thick.
One aspect of what I'm doing is a flash boiler down the center of the tailpipe, with a rocket nozzle at the tail end. That way, you can use 3-400 psi steam with a fairly thin walled boiler. Art to post later!
Scavenging the heat from the outer wall of the pjet is the next bit, but my prototype is only using the above internal boiler.
This is why I was looking for steam nozzle designs a while ago.
I'll just tell you.
re: Water Injection
Here's the art. Increasing surface area and extracting more heat with tail expansion are metrics to work out.
- steamboy.jpg (12.98 KiB) Viewed 5660 times
re: Water Injection
Mike are you having as much fun as I am listening to everyones ideas?
For efficiency, the overall consumption would be similar to the fuel consumption rate of the normal base pulsejet.
For max power a ton of water could be injected, but the best quantity that yeilds the most gain per volume of water is considerably less, well worth the increase in thrust, especially when coupled with other things.
I am not going to reveal the specifics of my preheating systems, but it does result in an engine that is warm to the touch :D
Oh and it doesnt use a pressure jacket, I would really really really avoid making a pressure jacket there are a ton of reasons not to use one, not including that they can be unsafe (aka explode), or potentially crush the engine.
Some people who are experienced with steam pressure systems will likely argue that it is easy to do, but if you are trying to get 300 - 400 psi like Mike there could be catastrophic results for the average self-taught-welding DIY'er who doesnt know any better.
Small diameter coiled tubing is definately the way to go, and it can withstand considerable pressure.
re: Water Injection
Agreed that coil heat exchangers are much safer, and of course where one would start if one were sane. On the safety subject, I am designing for 250psi limit for now. As I increase the pressure, at least if mine grenades, it's inside a steel shield!
re: Water Injection
Bah! Dont build one like that... they work horribly .... actually ... they dont work at all... yes .... they dont work at all
re: Water Injection
Why not put a pressure release plug on it, so it will blow the plug before it blows the main tube.
Re: re: Water Injection
ha ah ha I think you're having fun with me!Eric wrote:Bah! Dont build one like that... they work horribly .... actually ... they dont work at all... yes .... they dont work at all
Rest assured, I will have a pressure release in there somewhere.
Man, that's beautiful.Mike Everman wrote:Here's the art. Increasing surface area and extracting more heat with tail expansion are metrics to work out.
Simon
re: Water Injection
hola, soy de argentina y tengo el agrado de conocer mucho sobre este tema, esto de al inyeccion de H2O en los pulsos, para argntina es algo viejo, este sistem fue patentado ena argenitna por gustavo mountafain, y es un sistema realmente facil de utilizar.
ventajas del sistema:
-aumente el 25% del empuje del motor
-reduce el consumo de cumbustible en un 10%
-reduce el ruido en un 14 a 18 %
-reduce la temperatura a unos 750°c
-no rompe margaritas por tiempos de hasta 63 hs
luego fijare mas informacion alrrespecto.
el los pulsos sin valvulas he utilizado el H2O para pruevas de fumigacion 3 litros de h20 se vacian el solo 15 minutos , en un lockwood de 1,5 kg de empuje.
hello, I am of Argentinean and I have the affability to know much on this subject, this of a the injection of HÒ in the pulses, for argntina is something old, this sistem was patented ena argenitna by gustavo mountafain, and is a really facil system to use. advantages of the system: - 25% increase of the push of the motor - the consumption of cumbustible in a 10% reduces - the noise in 14 reduces to 18 % - the temperature reduces to 750°c - hs does not break daisies per times of up to 63 soon alrrespecto will fix but information. the pulses without valve I have used the HÒ for pruevas of fumigation 3 liters of h20 vacian single the 15 minutes, in lockwood of 1.5 kg of push.
FRANCISCO COOREMAN
FRANCISCO COOREMAN
- pulsfogp.jpg (15.08 KiB) Viewed 5630 times
- swingfire_principle.gif (11.42 KiB) Viewed 5632 times
- Imagen136.jpg (16.65 KiB) Viewed 5629 times
- Imagen135.jpg (12.98 KiB) Viewed 5628 times
- Imagen137.jpg (14.08 KiB) Viewed 5629 times
re: Water Injection
Ok, I am going to use a coiled water jacket, but could you explain the different water injection locations, and there respected performance enhancements.... Also how much water can the engine truly take on, do I need a bigger tube than 3/8" ID?
Louder is ALWAYS Better!!!
Thanks, Al!Al Belli wrote:Hi Bruno,
Propane is slightly soluble in water, 65 cc/L.
Acetylene is a better choice at 1000 cc/L.
Source: CRC Handbook of Chemistry and Physics.
Al Belli
The idea is, of course, to kill two birds with one stone.
Not a very simple solution -- engineers will cringe at the thought of a tri-propellant engine -- but since the engine is bog-simple itself, and the yield boost potentially huge, why not consider it? Fire the engine with diesel as the prime fuel and inject it with water laced with acetylene.
But -- a thought occurs to me as I write this -- once the engine is up and running with diesel, perhaps a water-diesel emulsion would work as both fuel and reaction mass.
Any opinions on that? I know that some piston engines have been run experimentally on gasoline-water emulsion but can't remember if anyone has ever done it with diesel.
re: Water Injection
What if the heat exchange coil was wrapped inside the CC instead of on the outside?
Since the intake/exhaust velocity is at its lowest in the CC it should not restrict the gasses much, and the heat exchange would be far greater since the entire surface area of the coil is subjected to the combustion heat instead of just the side that is closest to the CC or tailpipe.
Stainless is a lousy heat exchanger and most pulsejets are made of it, so it makes little sense to me to wrap the coil around the engine...
//Anders
//Anders
Well, if you're preheating water using the _internal_ heat of the engine, you gain very little over just injecting it cold - you're still using the heat internal to the engine to heat the water. If you are using the external "waste" heat of the engine you're effectively putting some of that energy back into the engine, no matter how inefficiently you're capturing it.Johansson wrote:What if the heat exchange coil was wrapped inside the CC instead of on the outside?
//Anders
That's the way I see it, anyway. But I'm probably wrong.
Simon
re: Water Injection
But the internal vapour coil would decrease CC wall temperature and therefore heat loss through the walls compared to an external heat coil where the heat exchange occurs after that the heat has traveled through the CC walls, so in my narrow mind it seems more effective to produce steam inside the engine.
The drawback is that the heat in the tailpipe cannot be used with this method.
//Anders
//Anders
Mike -Mike Everman wrote:The outer jacket will not work for a flight system because the pressure will crush the pjet unless it is quite thick.
A clarification: What I was originally proposing was NOT a reservoir of liquid water around the engine - it was just a small-volume jacket into which water would be sprayed through modrate-pressure nozzles. The idea was not to create pressure, but just add mass at a moderate velocity to the tailpipe exhaust stream. The water would be in a tank similar to the fuel tank, and driven in with a pump or air pressure. The vapor pressure in the jacket would be no more than the average chamber pressure.
