Sure. From one doddering old coot to another, here's what I mean:hinote wrote:Hi Larry:Larry Cottrill wrote:Bill -
OK, since you promised not to knock any ideas ...
I wish there was some simple way you could experiment with the spacing between the exit face and the intake flare. I think they are a significant fraction of a wavelength apart (in cold air terms) and there could be some out-of-phase interference felt at the intake. Consider how carefully the longitudinal spacing is set up in the classic Ecrivesse. If you practically eliminate the longitudinal spacing, the lateral spacing between the axes of the duct ends might be pretty critical.
I'm sorry, but I'm not totally sure about what you're trying to convey here; could you expand on the concept (or maybe simplify it, for us old guys)?
The phasing of the pressure waves between the exhaust and intake is surely capable of affecting the breathing of the engine if the phasing happens to be suboptimal - at least, the designers of the Ecrivesse thought so, and scientifically spaced the intake and exhaust at what they thought was a good separation, pretty far apart. Lockwood's original design, however, had the intake and exhaust in almost the same plane, though well separated axis-to-axis. I think basically what you want to avoid is phasing such that the emergent pressure wave from the exhaust goes down through the intake just in time to "fill in" the low pressure reflection wave as it gets back up the tailpipe to the chamber. That it can do this is not intuitively obvious where the external distance between the ports is small, but that's because we don't intuitively "see" the speed difference between the wave inside and outside the engine.
You introduced me to the idea of the "acoustic point" out somewhere beyond the open port face of both the exhaust and intake. But consider: one implication of the "acoustic point" is that it is the point in space from which the pressure wave radiates omnidirectionally after it exits either port! What this means is that to show the proper wave path distance between the exhaust and intake ports of your engine, we have to visualize it as a diagonal line between the acoustic points of the ports, NOT just a longitudinal measurement between the port faces!
The phasing will depend on this acoustic wave path length AND the realitive sonic speed in the tailpipe gas and the cool outer air. Wave travel will be MUCH faster inside the engine (high temp, low density) than in the air between the ports. In an engine like yours, there will always be a fresh supply of cool air in the region between the ports, because of the flows in and out of the ports - there will NOT be any hot gas hanging around out there! What this means is that the diagonal wave path between the acoustic points seems like a tiny fraction of a wavelength, but is really much more significant, because it's in a region of low wave speed, i.e. the basic engine frequency AND its harmonics have a far SHORTER wavelength in air than they do in the engine interior. Thus, it may be possible to get bad phasing between intake and tailpipe even though the distance is small. Also, if the path length is small, a lot more of the pressure wave energy gets into the intake than if the distance were longer, since the radiation of the wave essentially obeys the inverse square law (twice the distance would have 1/4 the impact).
I would conclude that it is not wise to have the intake and exhaust ports close together unless you are able to plan the phase relationship very carefully, at least for the case of the fundamental frequency.
