EDK0301B Engine
ed knesl
EDK0301B Engine
Post by ed knesl » Wed May 25, 2005 1:48 am
Here are some images of my new valveless motor. As you can see it is
brand new, still "in the box".
It is all 22 and 24 ga SS, mostly spot welded except intake stem
and front lid, 74 mm diameter, intake length is adjustable.
edward
(165.75 KiB) Downloaded 798 times
resosys
re: EDK0301B Engine
Post by resosys » Wed May 25, 2005 1:51 am
Ed,
That is beautiful. I can't wait to hear about your test runs.
Chris
re: EDK0301B Engine
Post by larry cottrill » Wed May 25, 2005 1:56 am
Yes, that is a beautiful job. Of course, I especially like that fact that it doesn't use a fancy transition cone from the intake into the chamber.
Good luck - I'm betting that will run as great as it looks!
ed knesl
Re: re: EDK0301B Engine
Post by ed knesl » Wed May 25, 2005 2:11 am
Ben wrote:Yes, very nice. Get video of the first start's spot weld slag sparks, if you have any way of doing that.
Have you started your mega-Chinese since the meet, or patched any of the holes?
Ben,
all holes are patched up, but I am setting that unit apart for liquid fuel
testing. This new one has to be tested first on propane and new CM6
plugs and new ignitor. Have to order parts yet.
ed
re: EDK0301B Engine
Post by Mike Everman » Wed May 25, 2005 3:31 am
Truly wonder-bar, Ed! Because of you and Mikhail, my next motor will be a Chinese, too!
Beaker
re: EDK0301B Engine
Post by Beaker » Thu May 26, 2005 10:32 am
nice job Ed, hope you have fun waking up the neighbourhood
ed knesl
re: EDK0301B Engine
Post by ed knesl » Sun Jul 17, 2005 9:36 pm
HI all !
Enclosed are three images of this engine improved from its original.
Combustion chamber had do be extended, Intake pipe shortened
and opening to CC enlarged, angle of intake entry decreased.
Reason for these : Engine needed forced air to sustain full "RPM".
After such changes : No problem with air, Easy start, Instant revup
and 8.1 lbs of thrust.
It blows away anything in a way of tail megaphone. Very powerfull !
Ed
(88.53 KiB) Downloaded 524 times
(136.61 KiB) Downloaded 521 times
(359.7 KiB) Downloaded 564 times
francisco
re: EDK0301B Engine
Post by francisco » Sun Jul 17, 2005 9:55 pm
wowww, congratulations ED
beoutifull engine.
your have dimencions??
FRANCISCO COOREMAN
fran_rio88@hotmail.com
re: EDK0301B Engine
Post by Bruno Ogorelec » Sun Jul 17, 2005 10:30 pm
Great stuff, Ed! Your engines rule!
re: EDK0301B Engine
Post by steve » Mon Jul 18, 2005 4:00 am
interesting heat pattern, care to comment on that?
re: EDK0301B Engine
Post by Mike Everman » Mon Jul 18, 2005 4:17 am
Ed, that's beautiful work. Was the 8.1 lb right before rich extinction? And how does the length of this one compare with the 66mm dia motor?
I'm hoping you have a sound file, over-all length and intake length to report at some point...
ed knesl
Post by ed knesl » Mon Jul 18, 2005 4:45 pm
Mike Everman wrote:Ed, that's beautiful work. Was the 8.1 lb right before rich extinction? And how does the length of this one compare with the 66mm dia motor?
Mike,
Yes , 8.1 lbs was right before choking.
One think is quite important - the ambient temperature.
It was done on quite cool night few weeks ago.
Now, at the blasting heat in Phoenix, I can get out of it merely 5.9 lbs.
Now I know, ambient temp makes a huge difference !
This motor is longer than 66mm, total 886mm.
Well I have now three different engines in great running conditions, they
are all stainless steel, they will last for a while.
Also I kepp files, cones parer patterns, everything is documented.
( Old 66mm no longer exists , built completely new front end for it of
a smaller diameter )
Ed
francisco
re: EDK0301B Engine
Post by francisco » Mon Jul 18, 2005 4:55 pm
it could fix dimencions of its pulsejet??
thank you very much
ed knesl
Post by ed knesl » Tue Jul 19, 2005 3:00 am
francisco wrote:it could fix dimencions of its pulsejet??
thank you very much
Francisco,
Unfortunately I am not ready to give out any detailed dimensions
at this time. I am in process of experimenting more, so these
engines are still working test beds.
Ed
Post by mk » Tue Jul 19, 2005 7:32 am
steve wrote:Interesting heat pattern, care to comment on that?
Well, I noticed it for my (non-Chinesy) engines, too, that glowing areas start at and extend later on up from joining sections. Merely in downstream direction first.
