I've got a pocket Lockwood too!
Post by Mike Everman » Thu Apr 14, 2005 6:27 pm
Mine fits in my pocket, sort of, and has a 2" CC. Have a few pinholes to plug at lunch, then I'll try it this afternoon!
It's volume is almost exactly 425ml, and weight is 1.25 lb.
(69.55 KiB) Downloaded 413 times
(169.88 KiB) Downloaded 472 times
resosys
re: I've got a pocket Lockwood too!
Post by resosys » Thu Apr 14, 2005 6:43 pm
Mike,
That first picture is priceless.
I'll find the time to build up a little one this weekend. We'll have a mini pulsejet jam session at the meet. We need an old R/C car chassis to we can do speed runs.
Any of the kids coming out to the meet?
Chris
Post by Bruno Ogorelec » Thu Apr 14, 2005 7:49 pm
A great, great picture -- on a par with Larry with his Elektra slung like a gun over his arm. I loved it! A nifty thing, this small feller. Hope it works well.
Post by steve » Thu Apr 14, 2005 7:50 pm
It kind of looks more like a mini escopette to me, minus the flared exaust. For it to be a lockwood shouldn't the intake be as thick, if not thicker then the exaust?
How do you plan to fuel it?
Post by Mike Everman » Fri Apr 15, 2005 6:05 am
Wwoooo-hooo!
The little guy started right up, even with 3-4 pin-holes in the welds (that I know about). I used the same 3/32" stinger that I used on the pipewood. It's not at the entry, but has a bend in it and run nearly all the way to the CC, but still in the intake.
OK, this is then installment two of "simple rules for building pulse-jets". I'll re-iterate the simple proportions in the next post.
Video attached.
(189.27 KiB) Downloaded 313 times
(144.28 KiB) Downloaded 328 times
straight pipe2 build.zip
(1.09 MiB) Downloaded 280 times
Post by Mike Everman » Fri Apr 15, 2005 6:14 am
Over-all length is 29.75, frequency is 237 or 243 depending on which video clip you use.
These 90 bend fittings are .865 ID. I've got a larger set that is 1.42 ID, time to start welding that one up.
Dave
Post by Dave » Fri Apr 15, 2005 10:49 am
Looking good!
Dave
Post by Eric » Fri Apr 15, 2005 3:13 pm
Thats awesome! How low can you get it to run? If its running real good you should be able to get it to purrr like a cat, just dont pet it.
Post by Mike Everman » Fri Apr 15, 2005 3:48 pm
I only had 15min or so. I showed no signs of quitting. It dials down to a purr, like you say. It's really nice to hold in your hand. It's only 14" long from bend to ends.
Post by Mike Everman » Fri Apr 15, 2005 10:37 pm
These stainless butt-weld 90 degree fittings from McMaster-Carr are great. Makes a nice, tight u-turn don't you think? Worth designing an engine around. They are specified in inches, but the ID's are closer to metric round numbers, 3/4" is .865 (22mm), the 1 1/4" is 1.4 (36mm).
They also have relatively cheap thin walled inch series od versions, like 1" outside, .065" wall. Dang, I should have used that! The ones I used are thick walled.
Post by mk » Sat Apr 16, 2005 5:35 pm
Really nice! Indeed.
So the stinger points perpendicular to the center line, and is still in the inlet, right?
Did you notice any coincidents with Eric's fueling point observations on the "Escopette-mod"?
Post by Mark » Sun Apr 17, 2005 10:11 pm
Man, where are all these engines coming from? Everytime I turn around, someone else is posting another. I'm running out of compliments! Good job Mike. Nice engine Mike, etc. for the rest of you too.
