hinote wrote:But, during the combustion phase, the intakes are converted to thrust-producing exhausts. With the fuel supply further into the engine at least part of the outflow will be re-entrained as it begins to beat in again.
Sorry, but I am not sure I understand what you are talking about. Please clarify. What will re-entrain the returning outflow? Where will that flow be entrained towards? What role does the placing of fuel injection play in the process? I have lost you completely.
hinote wrote:Remembering that the combustion chamber is only filled to the extent of something like 20%, I don't think it's wise to move the fuel source too far back.
No, it is the entire engine volume that is filled to something like 20 percent. One tries to design the engine so that those 20 percent are within the combustion chamber.
hinote wrote:You're going to end up with intake tubes filled with fuel/air mixture at the point of combustion---and these are going to go off like separate entities (if they go off at all) and not contribute anything to the needed primary pressure event in the combustion chamber.
Point taken. This layout will not be high on the fuel efficiency scale. Is this maybe a good case for (Shock! Horror!) timed injection?
hinote wrote:Based on my (very limited) experience with liquid fuel delivery, all you're going to get with atomizers at the inlet mouths is one or more very wet intake tubes.
Maybe. You may well be right. On the other hand, there must be injector nozzles that deliver atomized fuel in a narrow cone. But, I take your point at least partly. I am probably influenced in my thinking by my insistence on gaseous fuel.
Viv wrote:I have to go with Bill on the last parragraph, high airspeed heat and turbulance are the main requirments for good atomisatation and the best place to find them is near that transition point from intake to combustion chamber. Thats not to say you cant find some of those conditions directly behind the intake lip but it lacks the heat input from the engine by conduction and by infrared radiation so we prefure the other end.
I agree on speed and turbulence and on the fact that they are to be found in the front part of the combustion chamber. But, saying that they are not good in a tubular ejector is like saying that it doesn’t rain in London. What I am saying is, here we have a perfectly good ejector/mixer and we are not using it. If we did, it would do at least a half of the job, with the other half left to be done by the commotion in the combustion chamber. I am not suddenly creating a still and quiet combustion chamber if I inject the fuel into the port, rather than into the chamber. I am just making its job easier. In fact, I wonder if the transition could not be made gentler and the internal drag lessened if half the atomization and mixing were already done by the intake stack. Something to think about.
I admit I was thinking primarily in terms of propane or gasified liquid fuel. Injection of liquid fuel is a bit different. However, look at the history of automotive fuel injection in spark-ignition engines and you will see that injection into ports is the rule. Injection into the chamber is a rare exception.
