Sighting of Lock Reynst Monster - Legend, Hoax or Reality?
Post by larry cottrill » Mon Feb 28, 2005 10:01 pm
For Mike Everman -
Since you have "proven" that the Reynst and Lockwood are merely transmogrifications of the same beast, why not build one?
Here's my bid for how it would be done -
The notorious, fabled 'Lock Reynst Monster' - go near if you dare! Drawing Copyright 2005 Larry Cottrill
Lock Reynst Monster.jpg (66.58 KiB) Viewed 16886 times
Re: Sighting of Lock Reynst Monster - Legend, Hoax or Realit
Post by Viv » Mon Feb 28, 2005 10:22 pm
Funny but Bruno has you beat by a year or two as he got Gary to build some thing remarably similar:-)
didn't work unfortunatly though:-)
Post by larry cottrill » Mon Feb 28, 2005 11:49 pm
Viv wrote:Funny but Bruno has you beat by a year or two as he got Gary to build some thing remarably similar:-)
Gary Robinson is a good builder, for sure. So, are you betting against it? I have the Hinote Criteria on my side, and I'm not sure Gary was blessed with that, though he has an awfully good eye. The proportions wouldn't have to be off by much, though, to keep it from catching hold.
I'm not exactly sure where to fuel it - maybe Rosscoesque, with a spray ring right upstream from where the intake air spouts in? Or, more Steve style, with a ring just inside the flare?
steve
Post by steve » Mon Feb 28, 2005 11:55 pm
Larry Cottrill wrote:I'm not exactly sure where to fuel it - maybe Rosscoesque, with a spray ring right upstream from where the intake air spouts in? Or, more Steve style, with a ring just inside the flare?
Its nice to be credited with something other then sparkplugs!
Post by Mark » Tue Mar 01, 2005 12:22 am
I have a Loch Ness Scottish design, (Scotland is said to be the only country where the ( ) couldn't make a living, (choose your ethnicity). The Scots are known for penny-pinching. Anyway, a very inexpensive valveless design could be made of very cheap plumbing pipe with a single washer sandwiched inbetween the front bell housing and combustion chamber segment. Then you could thread in a front intake snorkel flush with the washer providing a reflective front barrier/wall very similar to the recent valveless designs that are being presented.
Post by Mike Everman » Tue Mar 01, 2005 12:25 am
Yeah, someone's got to do it. I posted one like it a while ago, and have probably sketched variants 20 times. I think the main problem will be getting the intake area right, and keeping it there.
then there's the LH variant that we've been toying with.
All are going to be dimension sensitive. Try some numbers, intake areas change wildly with little tolerance.
I think with our new "understanding" of length proportions, we can get there.
(181.42 KiB) Downloaded 1080 times
(104.5 KiB) Downloaded 1117 times
hinote
Post by hinote » Tue Mar 01, 2005 12:48 am
But Larry--
(nothing's new!)
--you've already posted something similar here, before.
Larrys SNECMA pulse comb measurements.JPG (19.41 KiB) Viewed 16831 times
Post by Dave » Tue Mar 01, 2005 12:50 am
Larry
If you are serious, and want to go BIG, I may have just the thing for the combustion chamber. Check out this widget.
(787.62 KiB) Downloaded 1086 times
Post by Mark » Tue Mar 01, 2005 1:28 am
But Larry--
(nothing's new!)
Bill, That one is out of my Pulsating Combustion Symposium book, the big convention in Sheffield, England.
(157.95 KiB) Downloaded 1028 times
Post by larry cottrill » Tue Mar 01, 2005 5:01 am
Well, all those are nice of course, but for Mike's proof engine, I just wanted something that really has that Lockwood "look and feel", but with Reynst breathing.
Post by Bruno Ogorelec » Tue Mar 01, 2005 9:44 pm
Larry,
Let me clear up something about Gary Robinson's Big Black Beast. He and I never had the benefit of the insight into the necessary geometry that you now have. We both thought that the inner end of the exhaust pipe should be fairly close to the chamber bottom.
If we were doing it today, I'd tell Gary to position the tailpipe exactly as you have drawn it.
Also, Gary had other things to attend to, so he only did a few unsuccessful tests before abandoning the project.
I can't remember the fueling system anymore. Maybe it was also less than conducive to success, but I don't think so. Gary always built great fueling gear.
(53.99 KiB) Downloaded 953 times
Post by Mark » Tue Mar 01, 2005 11:44 pm
To me it looks to have too much gap between the exhaust pipe and the combustion chamber, letting all the compression escape prematurely.
Post by Mike Everman » Wed Mar 02, 2005 4:27 am
Yeah, it had way too much intake area. Good size, though.
Post by larry cottrill » Wed Mar 02, 2005 3:59 pm
Dave wrote:Larry
Dave -
If you can publish even a crude drawing that shows the exact dimensions, we can design one that YOU can built out of it ;-)
As you can imagine, the final result will be about 3x as long as the piece you have there. You would need to be able to put a decent flare around the rim that's at the bottom in your picture, and weld a plate across the rim at the top [unless maybe it's already closed off?].
parajet27
Post by parajet27 » Fri Aug 01, 2014 10:07 pm
Hey there,
I was just curious to see if anyone had ever followed up on your lock reynst idea. It seems absolutely brilliant to me.
I can see how the gap eliminates the need for external intake ports to be added. With the proper ratio of intake gap
area to exhaust area it should act just the way the intake ports work on other closed front engines. You've given me
alot to think about.
