Looking for plans? Look here.
Tom
Post by Tom » Sat Jan 29, 2005 6:43 pm
Admin Edit:
Most of the links below reference "phpbb2" in the address. You will be able to get to the right place if you change phpbb2 to phpbb3. The main site plan links are down. We're working on that, as of 6-2-2008.
Regards,
As we have many people come here and ask for plans for the engines, I thought I would make it clear that many of the plans that exist can be accessed Here, the main page of this website. Other sources include within the forums of the engine type you seek. For example, search in the Jet Engine forum for plans of the KJ-66 engine, or seach in the Valveless forum for plans like the Short Lady, that aren't on the front page. Also, contact GLC Inc., Run by two of our members, Viv and Luc, for high quality plans and kits of certain engines, with more to choose from as time goes on. Hope this helps.
Tom
If anyone else wishes to add to this, either reply or send me a PM and I will edit in as soon as I can.
Re: Looking for plans? Look here.
Post by mk » Wed Mar 02, 2005 5:32 pm
Search the pages of the following topics to find dimension drawings and fuel injector shape and placement tests to my K-PT engine series.
http://www.pulse-jets.com/phpbb2/viewto ... sc&start=0
http://www.pulse-jets.com/phpbb2/viewtopic.php?t=780
Note to fuel injectors: It has been experieenced that way simpler injectors do a better job then the tricky "swizzle stick" designs -- the "fuel stinger" designs. See FWE topics or so for more information about.
Mike's Kazoo and Kazooenstein -- partial Kazoo/squeezed -- engines.
http://www.pulse-jets.com/phpbb2/viewtopic.php?t=262
http://www.pulse-jets.com/phpbb2/viewto ... c&start=15
"Nanosoft's" Lockwood-Hiller patent engine and the SP-14 derivative engine.
http://www.pulse-jets.com/phpbb2/viewtopic.php?t=847
A big Lockwood-Hiller engine.
http://www.pulse-jets.com/phpbb2/viewtopic.php?t=1047
The Chinese engine dimension drawing can be found via the pulse-jets.com main site.
Note to fuel injecion: They should also be used the "fuel stinger" injector type, just as the Chinesy FWE/Elektra uses.
Enjoy.
re: Looking for plans? Look here.
Post by larry cottrill » Tue Aug 02, 2005 7:23 pm
COTTRILL VALVELESS PULSEJET DESIGNS
Here are recent designs of mine that are either known to run or are closely based on successful earlier designs. I do not usually draw highly detailed plans, and all drawings are published either as part of Web sites specific to a design or posted here on the Valveless Pulsejets Forum. These are listed in order from oldest to most recent.
Where I indicate 'DJ dimensions', it means that the overall engine size is practically identical to the standard Dynajet valved engine: 21 inches head-to-tail, 1.25 inch tailpipe diameter and 2.5 inches max. engine diameter.
Valveless Pulsejets Built and Run
Reynstodyne Elektra I 'Five Dollar Pulsejet' - good running, low cost and easy to build, but rather long and not very powerful -
Construction site page: http://www.cottrillcyclodyne.com/ElektraI/ElektraI.html
Test Journal Page: http://www.cottrillcyclodyne.com/Elektr ... raI_2.html
Original Forum Post: http://www.pulse-jets.com/phpbb2/viewtopic.php?t=503
First Run Post: http://www.pulse-jets.com/phpbb2/viewtopic.php?t=622
Reynstodyne Elektra II 'Five Dollar Pulsejet' - improved version, somewhat harder to build, somewhat more compact and more powerful -
Original Post: http://www.pulse-jets.com/phpbb2/viewtopic.php?t=856
First Run Post: http://www.pulse-jets.com/phpbb2/viewtopic.php?t=1102
Reynstodyne Fo Mi Chin Prototype - the original shaving cream can pulsejet - ran well but very difficult to build and 1.2 metres long - listed mostly for historical interest -
Original Post: http://www.pulse-jets.com/phpbb2/viewtopic.php?t=637
First Run Post: http://www.pulse-jets.com/phpbb2/viewtopic.php?t=1540
Reynstodyne Fokus 'Short Lady' - the classic Focused Wave Valveless Pulsejet Engine (FWE) - easy starting, good running, fairly powerful, fairly easy to build, compact size and good looking, too - independently built and tested by several people with differing skill levels -
Construction Page 1: http://www.cottrillcyclodyne.com/Focuse ... _Wave.html
Construction Page 2 and Testing: http://www.cottrillcyclodyne.com/Focuse ... ave_2.html
Original Post: http://www.pulse-jets.com/phpbb2/viewtopic.php?t=982
First Run Post: http://www.pulse-jets.com/phpbb2/viewtopic.php?t=1004
Reynstodyne Fo Mi Chin Type II - also very hard to build but proved to be a good-running engine and much more compact than the original Fo Mi Chin prototype - features unique quasi-concentric intake to minimize engine cross section profile and reduce the engine to DJ dimensions -
Original Post: http://www.pulse-jets.com/phpbb2/viewtopic.php?t=1767
First Run Post: http://www.pulse-jets.com/phpbb2/viewtopic.php?t=1848
Untested Designs Based on Successful Engines
Reynstodyne Fokus FWE 'Sveldt Lady' - the successful Fo Mi Chin II style in-line intake applied to the classic FWE planform, but shortened slightly to DJ dimensions -
Original Post: http://www.pulse-jets.com/phpbb2/viewtopic.php?t=1895
Reynstodyne FMC II - very precise adaptation of the Fo Mi Chin Type II in an easy-to-build format, eliminating the paper thin and troublesome pressure can, but requires rolling chamber cylinder and cones - should run exactly like the Fo Mi Chin II, with DJ dimensions -
Original Post: http://www.pulse-jets.com/phpbb2/viewtopic.php?t=2099
Reynstodyne Fokus FWE IV 'Smooth Lady' - the easiest-to-build form of the FWE design - no bent intake, no split shell intake like the FMC II and Sveldt Lady - very simple construction and should run just like the classic Short Lady - DJ dimensions -
Original Post: http://www.pulse-jets.com/phpbb2/viewtopic.php?t=2146
Ten Dollar Jet Engines Web Log:
http://tendollarjets.blogspot.com
Plans and/or other helpful engine construction information are featured in all these locations, though in some cases you will need to scroll down through the posts to get the whole picture. There are also many construction photos, some scaled patterns for the cone sheets, etc.
Enjoy!
Tom
Post by Tom » Tue Aug 02, 2005 8:34 pm
Thanks Larry. Steve and Marten, Your posts have been Deleted and Edited respectively. Apollogies, Just keeping this simple.
Post by steve » Sat Aug 06, 2005 5:54 pm
LINEAR "FOCUSED WAVE ENGINE"
Plans:
http://www.pulse-jets.com/phpbb2/download.php?id=2860
Development:
First sucessfull run (bottom of the page):
http://www.pulse-jets.com/phpbb2/viewto ... c&start=45
WORLD'S SMALLEST LOCKWOOD (?)
Plans (the dimentions are a little hard to read):
http://www.pulse-jets.com/phpbb2/download.php?id=3198
Development and first successfull run:
Another successfull mini lockwood build:
http://www.pulse-jets.com/phpbb2/viewtopic.php?t=1912
"PIPEWOOD" (weldless pipe-fitting engine)
Plans:
http://www.pulse-jets.com/phpbb2/download.php?id=7231
Development and first run:
Another successfull Pipewood build:
http://www.pulse-jets.com/phpbb2/viewto ... 55&start=0[/b]
Graham C. Williams
Post by Graham C. Williams » Sat Nov 25, 2006 8:22 pm
Mark 42
Post by Mark 42 » Mon May 21, 2007 6:52 pm
Graham C. Williams
FWEVIII REV06
Post by Graham C. Williams » Tue May 22, 2007 12:24 pm
FWEVIII REV06
Perhaps only for the advanced builder but a nice sport motor with some real thrust.
For further information see:
viewtopic.php?t=4085
The attached file is a zipped up autocad dwf file. Download the free viewer here:
http://usa.autodesk.com/adsk/servlet/in ... eID=123112
Graham.
FWEVIII Rev 06 James D-Model.rar
(5.05 KiB) Downloaded 1222 times
Last edited by Graham C. Williams on Mon Jun 02, 2008 10:59 am, edited 1 time in total.
Dark days nurture new
light. Productions begin.
Now open your eyes.
Propane Injection
Post by PyroJoe » Tue Dec 09, 2008 6:06 pm
Here are links to useful propane injectors.
Rosscojector
viewtopic.php?f=3&t=4212&p=48580#p48580
GRIMs 3-point
viewtopic.php?f=7&t=4688
GRIM
Post by GRIM » Thu Dec 11, 2008 9:43 pm
And this will set you up for a cylinder fitting
http://www.harborfreight.com/cpi/ctaf/d ... mber=65404
Irvine.J
Post by Irvine.J » Fri Dec 12, 2008 2:08 am
Rosscojector
http://pulseairdefence.com
ace_fedde
Free Piston Jet, new forum?
Post by ace_fedde » Wed Mar 04, 2009 8:44 pm
This one is valveless :lol: but it's not a pulse jet :roll:
Where can I post these plans?
CAD.pdf
(1.11 MiB) Downloaded 926 times
Free Piston Jet.zip
(1.26 MiB) Downloaded 766 times
Re: Free Piston Jet, new forum?
Post by Mike Everman » Wed Mar 04, 2009 9:58 pm
ace_fedde wrote:This one is valveless :lol: but it's not a pulse jet :roll:
This is as good a place as any for now. I will be making a thread that has only our recommended plans. Nice to see the loudmouth plan, I always wanted to see the inside of one of those. Thanks!
LOCKWOOD PLANS
Post by PyroJoe » Wed Mar 11, 2009 2:07 pm
*******LOCKWOOD PLANS*******
Sweet build by Dang911 with information on
Injector with alignment bracket and injector placement by Eric Beck of http://www.Beck-Technologies.com
Link:
viewtopic.php?f=3&t=2885&hilit=lockwood+startup
"where to place sparkplug and fuelinjector on Lockwood"
Pictures of injectors and illustrations
Link:
viewtopic.php?f=3&t=2840&st=0&sk=t&sd=a ... od+startup
Double click on the picture below for more detail.
Muffler Shop Special
Post by PyroJoe » Fri Jun 19, 2009 2:19 pm
One of the better designs for a beginner, or for someone who cannot weld and has a muffler shop nearby:
viewtopic.php?f=3&t=4515
