I'm planning on building a full size AS 014 pulsejet in the near future. I haven't been able to find the exact designs i need for the valve but i think i've figured out how thick the steel should be (i used the size of the valve and a drawing of the valve which showed how many reed valves there were i guesstimated the rest).
What i couldn't find and am not sure about is how thick the valve plate should be (the flap) and which material i should use for it.
Could anyone tell me what material and the thickness of the valve plate?
Thanks in advance
Argus AS 014 valve
Re: Argus AS 014 valve
Found it!
