my 140+ lb thrust argus style pj build
I found plans from scientific supply,for this beast! I'm going to make a ice sled with this PJ, I plan on running it on 50/50 gas and diesel,using 4 6gal per hour oil furnace nozzeles, it will produce 3millon btu's of heat! & give me a fun ride on the ice! I'm sure!
Re: my 140+ lb thrust argus style pj build
Looking good! How are you going to build the valve-plate?
Hello,I had to farm the valve register out to a machinist, its being done on a CNC,& is almost completed, can't wait to get it up&running! Should be impressive!!!
What kind of fuel pump do you use and wich nozzles?
Hello, I will experiment with lp gas For starting & or pressure my liquid tank w/lp, or 4 elect.fuel pumps,as for liquid nozzles" (4) - 6 gph solid cone spray pattern oil furnace nozzles,I can run it on lp only,but I want to try liquid fuels,oils & or methanol,ide sure like to test it this winter on a ice sled,I'm sure it will keep us all warm" with three million BTU's of heat energy being produced!!! Nice bonus!!!
Hello everyone, here is my valve register,I have to make the valves out of .010 spring steel yet,but making progress.
Success at last,its just ideling on propane,but runs&sounds very cool!!!
Looking good! feed it some gasoline or diesel when it's running and make a video!
