Brand new Dynajet
Brand new Dynajet
Just letting you know,Curtis dyna fog still sells the head assy. part of redhead DJ, I purchased it w/a extra lock ring,&constructed a new combustion tube, it started instantly! Very exciting!!!
Re: Brand new Dynajet
gettylee,
I don't mean to rain on your parade but your Dyna-Jet is not new; someone polished the red anodizing off the head fins.
This has absolutely no effect on its operation even the fins can be removed without harm, but I can't fathom why any one would remove the coloring.
Also, your chosen spark plug appears to be larger than the original; a 3/8-24 Champion V is quite satisfactory if the ground electrode is removed. The plug might last longer if it is moved forward about 1/2 in. in the combustion chamber. It will be a little cooler there.
Always wear hearing protection! I suffer hearing loss due to my testing many D-Js and larger pulsejets when I worked for Tenney in 1949-1952.
I'm still working on my D-J book and hope to get it to the printer this summer.
Jerry
Jerry
Louder is always better.
Hi,yes it is new,I bought two of them from Curtis dyna fog,I sanded the fins,to give it a little carictor, so it matches my homemade combustion tube,plus I won't get cut on them,I'm going to make another DJ & I'll leave it red, lol
Here is what it looked like before I sanded the fins,I talked to Mauricio @ dyna fog,that's how you can get just the head assy.no combustion tube though, that have some parts left over also. Fun stuff!!!
