need help,can anyone identify this engine?
gettylee
Post by gettylee » Mon Feb 18, 2013 11:17 pm
I built a successful fwe valveless,than saw a pic of What I thought was called a hpx I built it with the same size front as the fwe, it had way more power than the fwe,I want to try liquid fuels,to try to get similar power per weight than a dyna jet,,,It may just fly a rc plane someday?so,I am looking for a working liquid system,thx much Brian
luc
Re: need help,can anyone identify this engine?
Post by luc » Tue Mar 26, 2013 2:04 pm
Tat's a small Thermo Jet variant with an evaporator coil around it ...
Good day,
Luc
Designer & Inventor
gettylee
Post by gettylee » Tue Mar 26, 2013 6:32 pm
luc wrote:Tat's a small Thermo Jet variant with an evaporator coil around it ...
Good day,
Cool,funny,I just build em So quickly, I don't find out what it is till after its done! ide really like to go for 100 to 200 lbs,valved or valveless,any suggestions? thx! Brian
luc
Post by luc » Tue Mar 26, 2013 7:52 pm
Hi,
Lockwood engine would give you that kind of thrust, although I'm not certain about the "200" lbs. If not, maybe consider a "Scaled Down" Argus.
Nice day,
Luc
Designer & Inventor
gettylee
Post by gettylee » Thu Mar 28, 2013 1:11 pm
luc wrote:Hi,
Nice day,
will this work&mabey I can go with 4 engines? The diameter is 2 3/16 id, although starting 4 may be a trick!I sure like the argus! Is there any scaled down argus plans? Or big valved PJ plans
luc
Post by luc » Thu Mar 28, 2013 1:33 pm
I'm not a Lockwood expert and there are peoples here, and/or drawings or plans on this forum that can help you build your Lockwood.
If you decide to build a lockwood, make certain your are using stainless steel, for I have nice movies showing guy wanting to cut on costs using steel, just to see their nice engine melt and colapse in 30 seconds.
As for the Argus, the only plans I have is to produce a full scale one and my time frame and job does not allow me to scale it down and/or put to much time for this topic.
Although I've steped foward making accurate suggestions I beleive, I can not go any further ... Sorry.
Maybe someone else here can assist,
Good luck,
Luc
Designer & Inventor
