valve casting
Moderators: Tom, WebPilot, larry cottrill, Mike Everman
valve casting
Postby evildrome » Tue May 15, 2012 11:35 pm
Hi All,
I have abandoned my original idea and modded it a bit. I was going for a dual one piece matchplate pattern but that was too ambitious.
I made a matchplate sure enough but with individual elements.
http://www.wilsonlogan.com/valve-casting.htm
So... another 4 to cast and a valve carrier assembly to make. And the valves. And the fuelling system and.... and... I'll get there in the end.
Cheers,
Wilson.
evildrome
Re: valve casting
Postby Mike Everman » Thu May 17, 2012 3:55 am
Hi Wilson, I hope all is well with you. Beautiful work, man!
Re: valve casting
Postby evildrome » Thu May 17, 2012 5:12 pm
Hi Mike,
I'm well. Suffering from raging poverty but other than that I'm fine.
I'm most proud of the wax master & RTV mould in this post
viewtopic.php?f=2&t=6534#p75600
That was real tough. The casting bit has had its moments but the master took months of experimentation. I blended my own machining wax, had to grind a tapered cutter to get the right draft, and so on, and so on.
Anyway, on the home stretch now.
I firmly believe that if large valved engines are ever to be affordable, the only solution is cast parts.
Cheers,
Wilson.
evildrome
Re: valve casting
Postby metiz » Thu May 17, 2012 10:52 pm
so where's my valveplate? :lol:
Return to Valved pulsejet forum
Who is online
Users browsing this forum: Google [Bot] and 2 guests
cron
