hello ...
i'm using a V-shaped valve system like this one :
http://www.google.com/imgres?imgurl=htt ... CDcQ9QEwAw
my design in attachment
but i feel the cone section is very small is it normal ?/
i'm using the book of " the enthusiast's guide to pulsejet engines" by Bruce simpson
will this design work ? jet with V-shaped reed valve
Re: will this design work ? jet with V-shaped reed valve
I'll bet you could make it a pyramid shape and get even better performance than with a V.
well i`m stuck with this shape of valves .... i try to build the engine starting with the valves dimensionsockmonkey wrote:I'll bet you could make it a pyramid shape and get even better performance than with a V.
thx
Oh well. You can always try it on the next one. There's always a next one.
