problem forum translator....
forum could put the root of the forum ..... pulse-jets.com always put to those who are Spanish and I can not use the translator does not have the root example pulse-jets.com/xxxx/Xxx/xxx
Re: problem forum translator....
This topic: viewtopic.php?f=2&t=6195#p73737
translation: http://translate.google.nl/translate?js ... 5%23p73737
Right-mouse button on the topic title, than properties, and you wil find the URL
I guess the forum translator issue has now been fixed. There used to be lots of issues regarding the translation for some time back then but Google translators have come up a long way back then so as to provide the most effectual and assorted translation services out there.
Advantages of diesel exhaust fluid ?
