Video of a Sagittario (Zmodel Zanin) powered by a 100mm pulsejet from Italy.
Model weight (dry): 4,5Kg
Flight: 3 minutes and 20 seconds with 1,5 Lt of Gasoline and Jet A1.
http://www.youtube.com/watch?v=WymNgZXLsRs
Some photos:
Bye,
Massimo.
100mm Pulsejet from Italy
Re: 100mm Pulsejet from Italy
Hey Pyro Joe
This is Sammy from Australia what an awesome plane I just love the sagittario I have purchased a 90 mm German pulse jet engine which I would l;ovce to install into a sagittario.
Is the 100 mm engine in the sagittario a German or italian engine? I am keen to purchase some plans of the sagittario so if you can help me with some information on how I may be able to buy some plans I would greatly appreciate it.
Hi Sammy.
The pulsejet is Italian.
It has the same principle of operation of Zanin (Zmodel pulsejets), but the engine is bigger (combustion chamber 100mm of diameter).
The model is the Sagittario, also from Zanin.
The drawings are a simple 3 views of the model, in scale 1:2, without any specifications because the model has fiberglass fuselage and polystirene+balsa wings and tail.
Regards,
Massimo.
Regards,
Massimo.
