Another pulsejet kick from Sweden
Re: Another pulsejet kick from Sweden
I realise that i need to order the matterial today if i am going make the deadline.
I can order 0,2-0,25-0,3-0,4 mm of stainless springsteel.
I was thinking 0.3mm thick and 38mm wide.
Because of the little time available i gambled and ordered the valves in 0.3mm stainless springsteel and hopefully it will work.
If someone think that it wont work or something like that it may still be possible to change the matterial if i call early tomorrow.
Maximum valve free length after the clamp plate?
36-37.5mm
Edit: The Solar PJ32 pulse-jet engine seems to use 0.010 in (0.254mm) reeds.
"The reed valves are
fabricated from 0.010 in.-thick blue-
tempered spring steel and bent
approximately 15°."
http://hv4all.com/pulsejet/ny/AIAA-2005-0228.pdf
approximately 15°."
Erik,
Check back here in an hour. It is presently, 01:20 UT
Have you picked a name for your machine?
Hmmm, this is not so good to read
Because of the high temperatures and impact forces experienced by the valves during operation, the valves tended to only last 10-15 min before requiring replacement.
Erik,
Check back here first thing in the morning (your time). It is presently, 02:42a UT
I'm going to need some more time to check my work and advance it further.
Erik,
I've computed for your pj (here, I have assumed NO tail flare, just a cylindrical straight-through section there)
I compute a dfr of 83.72/200.3 = 0.418 which is already close to 0.431 . You'll have to make the valve clamp plates a little less wide to lengthen the effective valve length, but ... according to my numbers ...
"Stay the course", Erik!
- total volume is 2721.93 in³ (44.604 ℓ)
- total length is 78.82 in (2.002 m)
- estimated (driving) resonant freq is 83.72 Hz ( ±5%)
Thank you, i am really glad that you could help of with the calculations. And i am also glad that my choice of matterial thickness wasnt that far off.
This evening i am planing to make the intake cone but i cant find any information how to calculate the dimensions.
How important is the dimensions of the intake?
Edit: I forgot to ask if you think i will need to limit valve travell and if so, how much?
With the intake stack on, and no valves in place, the engine should also go into resonance with a tuning fork, oddly enough without the valves and at room temperature the engine will resonate at about the mid range of its operational frequency.
I am not sure if i understand what you mean?
Here is a mock-up of how the kick will look when its finished.
Haha awesome!
That's going to be the loudest race ever with you and Anders
Geez Louise!
