Back to Basic
Re: Back to Basic
Post by PyroJoe » Fri Nov 13, 2009 1:38 am
From the help file:
"In Just BASIC, numeric variables hold either a double-precision floating point value, or an integer. A floating point value will be converted to an integer if its fractional part is zero when it is assigned to a variable. Integers in Just BASIC can be huge."
"Only nine digits are displayed when floating point values are printed, unless the USING() function is used to force the display of the number of digits desired after the decimal point."
WebPilot
Re: Back to Basic
Post by WebPilot » Fri Nov 13, 2009 2:48 am
Hey Joe, (sounds like a song, doesn't it?)
By default, it works in double precision? OK, I remember it was pretty accurate 'right out of the box.' I use to do a lot of programming in BASIC; it was accurate enough to do fractals.
I found the time to look at your code, and yes, I was going to suggest that every time you assign a variable a value, that you use decimal notation not an integer. Always use floats unless you really mean an integer, like exponentials in powers.
for example:
9 pi = asn(1.0) * 2.0
14 l=0.0
25 I=w*h^3 /12.0
As you read, if the interpreter is called upon to do integer division, it throws away the remainder. If it then assigns this division to a float value, the result could contain HUGE errors.
~ but that's not your problem
The deviation is caused by your value for ' input4 .457
Here is a log of a run I did of your code in the interpreter I can use. I performed only one modification, the asn(1.0) replacement.
Your code results now match the results in my original post:
Congrats!
Re: Back to Basic
Post by PyroJoe » Fri Nov 13, 2009 3:10 am
Thanks, thought that input4 looked suspicious,
hitting dead center now:
code3.zip
(868 Bytes) Downloaded 86 times
WebPilot
Re: Back to Basic
Post by WebPilot » Sun Nov 15, 2009 9:53 pm
From the help file:
I've been doing some testing with my BASIC interpreter and here are some behaviors that I discovered.
  1. assigning a variable the value of one integer divided by another with no remainder gives an integer:
    bwBASIC: c = 4/2
    bwBASIC: print c
    2
  2. assigning a variable the value of one float divided by another with no remainder gives an integer (as predicted in the above quote):
    bwBASIC: c=4./2.
    bwBASIC: print c
    2
  3. Dividing 2 integers gives a float:
    bwBASIC: print 2/3
    0.6666667
  4. Dividing 2 floats also gives a float:
    bwBASIC: print 2./3.
    0.6666667
  5. assigning a variable the value of one integer divided by another gives a float:
    bwBASIC: a=2/3
    bwBASIC: print a
    0.6666667
  6. assigning a variable the value of one integer divided by another and using the INT command gives an integer:
    bwBASIC: a=int(4/3)
    bwBASIC: print a
    1
  7. finding the remainder when dividing two integers using the MOD command:
    bwBASIC: b=5 mod 3
    bwBASIC: print b
    2
  8. the INT of the division of two floats gives an integer:
    bwBASIC: a = int(4./3.)
    bwBASIC: print a
    1
  9. finding the remainder of the division of one float by another using the MOD command gives an integer:
    bwBASIC: b = 5. mod 3.
    bwBASIC: print b
    2
CONCLUSION:
It seems ok to mix floats with integers in BASIC; I don't do it.
I still advise the reader to use floats whenever one means floats and integers for loop variables and most exponentiation. It is a good habit to get into doing. Other programming languages make the distinction between the two and you will be "one step ahead of the rest" when you get there.
WebPilot
Re: Back to Basic
Post by WebPilot » Fri Nov 20, 2009 7:35 pm
It was not my intention to 'scare' anyone with my previous post. I was just being rigorous.
Re: Back to Basic
Post by PyroJoe » Fri Nov 20, 2009 9:00 pm
BASIC is probably a blessing for those running loose. No telling how many retired "sketty" coders are out there. Maybe be as many as half a billion or more.
Read in the past, the early release of FORTRAN took 20 people 7 years to write, resulting in accumulated 140 years to complete. Can only imagine a lifetime passing in code compared to my own brief experiences.
WebPilot
Re: Back to Basic
Post by WebPilot » Sat Nov 21, 2009 12:08 am
I learned FORTRAN first in order to program mainframes.
I learned BASIC in order to program a Tektronix graphics workstation and those home pcs that had the code burned into their ROMs.
I've been wingin' it ever since.
WebPilot
Re: Back to Basic
Post by WebPilot » Wed Nov 25, 2009 12:11 am
Having read my other thread, Computing volume … estimating cycle freq, you know I moved on to C.
Re: Back to Basic
Post by PyroJoe » Wed Nov 25, 2009 3:05 pm
C was somewhat the defining line, better programmers picked it up, many had disdain. I could not tolerate the taste of C, only writing a few programs.
It was tragic how many BASIC programmers dropped out of the game after C.
Ghrey
Re: Back to Basic
Post by Ghrey » Fri Nov 27, 2009 5:48 am
<<< Darth Vader sound effects on >>>
I am still here.
<<< Darth Vader sound effects off >>>
In all seriousness though it is some what astounding how much has been done with BASIC.
Thanks for the blast from the past guys.
Life still complicated.
Re: Back to Basic
Post by PyroJoe » Thu Dec 03, 2009 3:35 pm
Found an old QBASIC.exe in my archives. downloaded the above code, renamed code3.txt to code3.bas, opened it in QBASIC and ran "as is". The results looked good except the code had some "!" marks.
WebPilot
Re: Back to Basic
Post by WebPilot » Sun Dec 06, 2009 3:39 pm
 I installed this compiler yesterday.
 It seems to be 21st century, industrial strength, multi-platform and backwards compatible with Qbasic. I have further testing to do.
WebPilot
Re: Back to Basic
Post by WebPilot » Mon Dec 07, 2009 5:01 am
 There are some interesting graphics examples provided with the software that I got to work. I'll have to see if I can somehow get one or two up here.
The above is one frame from an extraordinary animation of
what is known as the Julia set.
Ghrey
Re: Back to Basic
Post by Ghrey » Mon Dec 07, 2009 5:21 am
I Recently installed Gambas on my Linux box, and the power supply died, but it seems to be a sort of Vbasic for real programers....
Take a look.
Ghrey
Re: Back to Basic
Post by Ghrey » Mon Dec 07, 2009 6:28 am
That graphic did not come up ::BEFORE:: I posted just .After.
Fractal animation in BASIC << Darth Vader voice on >> Impressive << Darth Vader voice off >>
Seems worth a look, when I get a new PS....
Oh wait this Mac still works!!!!
