A while back, I obtained a copy of this book, "Cybernetics - Control and Communication in the Animal and the Machine" (Wiener 1948). Little did I know then, I would find an application for it, now.
If you're unsure what this science is go here:
http://www.scholarpedia.org/article/Cybernetics
Surely, you've all wondered why a pulse combustor oscillates? Or wondered why when you first ignite it, its intensity increases or decreases until it seems to 'lock in' to some equilibrium running point?scholarpedia.org wrote:
Wiener himself emphasized the role of feedback mechanisms in the goal-oriented systems.
Feedback control is an invisible thread in the history of technology, as studies on mechanical clocks, steam engines, aerodynamic and electronic devices show (Bernstein 2002). A device designed to measure and regulate the speed of a machine, called 'governor' was successfully built by James Watt. Interestingly, James Clerk Maxwell had a paper "On Governors" (Maxwell 1868), in which he anticipated some aspects of modern control engineering (Mayr 1971).
There is a 'governor', or a 'feedback mechanism' at work in a pulse combustor and I think, I have discovered one. This 'invisible thread' makes my mathematical model 'lock in' to one of two stable limit cycles.
If there is interest, I shall continue ...
(c.t.)
