model kb70
Re: model kb70
Do you have any video or more info about your engine?
Re: model kb70
Hello
you are using the name KB70 for your engine but the helmond Delta was named like that
you realy not wanna know where KB 70 stands for hahahahahahahaha
Re: model kb70
hello friends, I do not get much in the forum and write English is not only Spanish, and I'm a translator makes me crazy.
This is pulse-jet engine combustion chamber measures like amt netherlands (Edmond)
but not the same I changed a thousand different things, because it currently marketed in Spain, but the valve, injectors, etc., an entirely been modified and improved, as this is for the market, I am currently making a fadecpj (full digital engine control autoriti pulse jet). that when available. has a temperature sensor, one pressure, and a fuel pump.
mi email: discotecapenelope@hotmail.com
speak spanisch.traduct english
clok spanisch 8:00 at 24:00 hour.
Re: model kb70
So, that's your first post after 5 yearsHello
