Hi, im building my first pulsjet. I have calculated dimentions for 78 lbs ( 35 kg metric ) of thrust.
Here is the dimentions:
Exhaust pipe diameter : 5 Inch
Exhaust pipe lenght : 34.11
Combustion chamber lenght :11.34
Exhaust cone lenght :11.34
combustion chamber diameter 7.28
I am going to use argus type valves.
The plate that the valves rest against has 5 slots measuring 45X17 milimeters.
There are 4 of these plates, two of them forming a "V".
It is two of these "V"s velded to the front plate that has 2 holes measuring
41.92X144.21 milimeters.
The angle between eatch plate of the 2 forming eatch "v" is 31 degrees
The valves are overlapping 3.4 mm of the edges in each slot cut in the valve resting plate.
For fueling i am planning to use 3 steel tubes drilled with small holes so the fuel can enter the combustion chamber.
These vill be located 3 inc deep in the combustion chamber.
So if anyone has some opninions on my design, ill be glad too hear.
HÃ¥ken
Norway
my first pulsjet
Try to build some kind of spoiler/ diffuser as they did for the Argus engine. In one of the documents I downloaded is the developement of this spoiler shown. It improves the air/fuel mixing process very much, by building up vortices behind this big shaped venturi. The free space next to the spoiler is a must in this case.
The valve angle looks ok. Retainer plates are useful when building V-cases. They should be at least as long as a half valve and should get curved shape with a bending radius of about 65...70mm (for valves to 35mm length).
I can't tell you whether the lengths are ok, sorry.
Good luck!
Good luck!
