Why not start a thread in which the pilots in this forum can share pictures of their Pulsejet plane(s)..
Here's mine.. The VD-001
The plane has got a 65mm Heinz Olarius engine.
We are going to fly under the name Voodoo pulsejet team Holland..
First flight will be done in Rothenburg, Germany during the DAYS OF THUNDER pulsejet meeting..
I will upload the video(s) of the flight(s) after the meeting (May 17-20th)
Well...I have showed you mine...now show me your's...
<< SHARE YOUR READY TO FLY PLANE >>
Hi Cliff, nice plane do you have there. I have one of these "purple" pulsejets too. They are VERY powerful for their size. Be careful with this small model and this kind of thrust :D
Pay attention if you start the engine. This can be riskful, because the fuelinjection is on the outside instead in the combustion chamber. See the picture below.
Nice to hear that you and your team will fly in Rothenburg. Hubert is a friend of mine.
In Rothenburg you will also see the deltamodel from Andreas Jeß powered with my XP90 engine. My next model will be such a delta from him.
- KB70 wiht XP90
- kb70mitxp90(5).jpg (63.27 KiB) Viewed 8431 times
- My first attemps in flying a pulsejet powered model plane.
Fire in the hole ;) - ichinflammen.jpg (23.95 KiB) Viewed 8431 times
www.pulsorohr.de
Last Update 20.05.07
Cover air plane
Hello Cliff
I want to know what do you use for covering your aircraft monokote or fiberglass or epoxy paint?
because on my pulse jet aircraft i use monokote and i can tell you when it burn that goes really fast it not seem the best for covering a pulso plane!
Maxime Chamberland
Maxime Chamberland
jet vehicals all types
Cliff: Mike gave us a slot for this! Jet Vehicles, All Types ! Good stuff to be found.
