My plane is almost ready!!
re: My plane is almost ready!!
I've done some shopping around and the only fuel pumps i can find run off 12V most only 30psi. Its not a major issue, though 8.4 V or so would be much easier with my current battery arrangement. Perhaps you could tell me the brand of your fuel pump, and I assume your running it off a normal 50amp or so speed controller? I have an E-sky 50 amp speed controller along with a range of Lipo 300/600 speed controllers, or did you make your own to controll current to drive the pump? If i'm in the ball park, please let me know. I've recently had an idea of windscreen washer pump... havent seen on yet as my "Corrolla" or should I say "Deathtrap" doesn't actually have one (EEK), but will take a look at my neighbours shortly.
Re: re: My plane is almost ready!!
"Flight Works, Inc.Number47 wrote:I've done some shopping around and the only fuel pumps i can find run off 12V most only 30psi. Its not a major issue, though 8.4 V or so would be much easier with my current battery arrangement. Perhaps you could tell me the brand of your fuel pump, and I assume your running it off a normal 50amp or so speed controller? I have an E-sky 50 amp speed controller along with a range of Lipo 300/600 speed controllers, or did you make your own to controll current to drive the pump? If i'm in the ball park, please let me know. I've recently had an idea of windscreen washer pump... havent seen on yet as my "Corrolla" or should I say "Deathtrap" doesn't actually have one (EEK), but will take a look at my neighbours shortly.
28265 Flechas
Mission Viejo, CA, USA
Phone/fax: (949) 855-4281
Or send us an email with your questions and comments at info@flightworksinc.com."
Try www.flightworksinc.com
you could try a pressurised fuel tank you can do this with a c02 gas bulb and regulator this is very light and reliable and once the fuel runs out the c02 passes through the engine extingushing any flame left because in rc planes weight is always a concern
i am a keen rc flyer and plan for my own pulsejet plane and plane to fuel it this way
i WILL get this pulsjet running even if my wife says i wont
I bought my fuel pump from here
it a behotec fuel pump 600 ml min and max pressure 115 psi
https://ssl.kundenserver.de/s69306567.e ... shopscript
I bought my fuel systeme from here!
http://www.americanrcboats.com/products ... gparts.htm
bubble free tank is a must on pulse jet engine one air bubble on the fuel line can kill the engine.
hello, I am of Argentinean, interests the subject to me. a question, single you use a fuel pump and an electrical cirucuito to regulate the caudal?
or he has something but in the injector?
you inject later before the valve plate or?
odria to especifiar something but on its form of injection and regulation of power?
some photos do not vendrian bad.
Francisco cooreman
Francisco cooreman
I'm dying to see how this plane went Max, please let us know asap.
I have to wait this summer now it to cold for start a pulsjet outdoor.
You could try mixing some ether in as fuel, I even have given engines a spritz of engine starting fluid when its extremely cold. Are you using methanol?
Also another option would be to make a quick remove propane injector that just sprays fuel into the intake until the engine is started. I have started even tiny engines on propane in temperatures down to -8 F. Though at those temperatures I wouldnt want to do any flying.
Hope you get a nice warm spell soon and can fly!
