I build a pulse-jet but it dont run, it only run some seconds an than it stops, what is the problem????. I use ASTM 1070 0,15mm tempered stell, is this a problem or no????
Please email me urgentlly!!!!!
Problems with my pulse-jet!!!!
Re: Problems with my pulse-jet!!!!
Sounds suspiciously like a fuel-delivery problem (starvation).Mathias wrote:I build a pulse-jet but it dont run, it only run some seconds an than it stops, what is the problem????. I use ASTM 1070 0,15mm tempered stell, is this a problem or no????
Is it carbureted? What kind of fuel are you using? If you're carbureted, what is the relationship of the fuel tank to the engine? Fuel line size?
etc., etc. We need more info to help you evaluate your problem.
Mathias
Mathias when you want to ask another question I don't think your supposed to post it as a new topic, but as a reply under the new topic you already have. We can still see that it is new as the flag on the post will be colored. I made this mistake early on and it gets the posts really cluttered so you can't tell what is actually a new topic or simply a reply.
thanks
Don.K
thanks
Don.K
