problems with craftjet injector
francisco
Post by francisco » Mon Jul 31, 2006 4:15 am
hello, am I copying the pulse craftjet, but do I have problems with the injectors of fuels which I should use? ? ? ? can somebody give me some idea? ? ? ,
I leave some pictures of the design here
so that the different types of injectors that are in the plane are? ?
francisco cooreman
pd: excuse my bad English
caveza craftjet.jpg (30.64 KiB) Viewed 4213 times
caveza craftjetcvnb.jpg (31.27 KiB) Viewed 4213 times
caveza craftjetcvvjmn.jpg (23.72 KiB) Viewed 4213 times
fran_rio88@hotmail.com
dynajetjerry
re: problems with craftjet injector
Post by dynajetjerry » Wed Aug 02, 2006 6:31 pm
Francisco,
I have a professionally-built Craftjet and, though I've never run it, it makes use of the upper style of injector. As you probably know, the lower drawing shows a simpler system but includes the entire valve head while the upper shows only the injector assembly.
If I were making one, I'd try the simpler design first. However, both systems are a little difficult to start unless the operator is familiar with them. The original design by Hiram Sibley included a starting fixture that was inserted into the Craftjet intake but may not have worked much better than a simple blast of air.
I'd like to make a helpful suggestion: Once your Craftjet is completed and assembled, start-up will be easier, probably, if the reed valve is not quite flat after installation. If it stands open a few thousandths inch (is curved a tiny amount,) starting is easier and exact fuel flow is less sensitive.
Jerry
Louder is always better.
Post by Mark » Thu Aug 03, 2006 1:53 am
I would use methanol for fuel.
Post by steve » Thu Aug 03, 2006 2:02 am
I was never able to get mine running on liquid fuel, but it ran great on acetylene directly injected into the combustion chamber.
hey what version of Solidworks are you running? that looks like some nice work.
you should post an e-drawing if possible
Post by Mark » Thu Aug 03, 2006 3:05 am
Acetylene is cheating, just look at the rich/lean ratio you have to be careful to fall into the range of flammability. ha ha
francisco
Post by francisco » Fri Aug 04, 2006 4:39 am
hello, thanks to all for their answers, I use solid works 2005, I have the following models drawn in solid works :
alpha
atom
dynajet
pulse 1
bms
craftjet
some but. .
I will try to fix some and-drawing
steve, do you have a post having fixed here on the craftjet, do I carry out some modification to the original planes?
first I will build the pulse and the nozzle,then I will prove with the injector but easy, it is that of the part of below.
all agree with this???
francisco cooreman
francisco
Post by francisco » Sat Aug 05, 2006 12:50 am
craftjet in e- deawins
Assem1.rar
(87.63 KiB) Downloaded 346 times
juki48
Post by juki48 » Fri Sep 01, 2006 2:12 am
I made mine with the more difficult needle valve and it turned out great. starts easily on propane and then I switch it over to meth. if you search under author Juki48 you will find the the posts under "plan #17 craft plane" I believe.
