Split pulsejet chambers
cbromano
Post by cbromano » Wed Jan 28, 2004 9:29 am
I am looking for either a patent or a design for some type of pulsejet with a split combustion chamber and some type of diaphragm between them. I figure it is a simple idea that has been thought about long before I did, but I would like to know if it ever worked as a way to increase compression.
Anyone know anything near what I am talking about?
CB Romano
Post by Bruno Ogorelec » Wed Jan 28, 2004 7:36 pm
I don't know of such an attempt, but I don't think it would work, either. First, the diaphragm would have to be very elastic to have any impact on the volume. Such a diaphragm would lst only seconds in the pulsejet environment. second, it would squeeze the chamber and force the charge out, rather than compressing it.
cudabean
Post by cudabean » Wed Jan 28, 2004 8:37 pm
I've thought of similar ideas.
One idea that springs to mind after seeing your design is rather than having a flexing membrane, have a sliding part, but then you have a moving part and all of its associated problems.
Another thing I thought of about ten years ago is to control the firing of the separate chambers by having a rotating valve on the front and rear which solves the problem that Bruno mentioned, but it also adds more moving parts which now must be powered in some way.
I personally think it is attractive to use the combustion of one side do the work of compression for another side. One simple way to achieve this is with a free-piston motor with combustion chambers on opposite ends. One side fires, moving the piston to compress on the other end.
cudabean
