Pulsojato Caipira!
Almeida
Pulsojato Caipira!
Post by Almeida » Sat May 21, 2005 10:42 pm
Olá Amigos entusiastas do pulsojato!
Sou de Tupi Paulista/SP, oeste paulista!
Estou montando um pulsojato, projetado com um software tirado da net!
Estou animado com a montagem, mas estou esbarrando em alguns problemas como o material para a valvula margarida, e tambem gostaria de saber se alguem tem algum projeto para o injetor tipo aspirado, montei o danadinho todo em aço, pasmem, retirado de latas de tinta spray, soldado com oxigênio, montei para experiência em bancada!
Estou próximo da cidade do Marcos!Gostaria de saber se vc conseguiu a chapa para a valvula!
Obrigado!
Jmitchell
re: Pulsojato Caipira!
Post by Jmitchell » Sat May 21, 2005 11:12 pm
je ne parle pas!
Anthony
Re: re: Pulsojato Caipira!
Post by Anthony » Sat May 21, 2005 11:42 pm
Jmitchell wrote:je ne parle pas!
It's Portugese, not French hehe!
Anthony
Jmitchell
Post by Jmitchell » Sun May 22, 2005 2:15 am
I know, I just don't understand why people post in different languages on an english forum??
Post by Bruno Ogorelec » Sun May 22, 2005 9:12 am
It's actually Danish. We're all lucky that Kenneth Moller, who established it after some work on jet engines with a circle of his friends in Denmark, refrained from sticking to Danish. Otherwise, we'd probably be forced to gather around Bruce Simpson's website or on the margins of the DIY turbine website.
There's a sizeable part of the pulsejet community in Latin America and those people generally don't speak English. Surely there's no harm in them having their own corner.
At the last count, we've had forum members from the following non-English-speaking countries (in no particular order):
Denmark, Germany, the Netherlands, Austria, Russia, Ukraine, Slovenia, Sweden, Taiwan, China, Belgium, France, Switzerland, Italy, Greece, Finland, Norway, Portugal, Spain, Iran, Argentina, Brasil, Peru, Dutch Antilles, Indonesia, India, Malaysia, Singapore, Nigeria and -- last but not least -- my own country, Croatia.
Yes, I counted them -- 30 different non-English-speaking countries. Pretty amazing, I think.
Hank
Post by Hank » Sun May 22, 2005 11:53 pm
Hello- Not to mention other various third world areas such as Florida and Northern New Jersey.....
Can anyone provide a translation. What I get out of it is this fellow has valves in his Margarita. The family lost the use of Portugese after the ships were burned some time ago. Seriously, we provided the wood the library in Lisbon is finished in.
I'm surprised there are not more posts here in some language unintelligable to most of us. Glad the baseline language is English.
Regards, Hank
pablo
Post by pablo » Mon May 23, 2005 1:14 am
OT
I'm getting tired of this
latinamericans (spanish people too, btw) seem to think that everyone should underestand what they say despite it's an english forum.
ok, so they can't write in english, then use a translator! (but then, they should write without spelling mistakes (almost impossible today, specially if they're 18 years or less, educations sucks nowadays))
so then i start thinking you get a bad picture of us, so i think it would be a good idea to ask them to use a translator and write correctly, to "organize" the forum a little bit
Pablo
Hank
Post by Hank » Mon May 23, 2005 4:12 am
Hello- Thank you for the translation, Ben.
Al- You need to use spring steel ~.006" for the smaller ducts with increasing thickness for larger ones.
Then there is the other side of the coin....People who become so provincial that all that occurs external to their small sphere of existense is alien. Add to that an influx of foreign peoples who are out to screw you and you have a recipe for a disaster.
Regards Hank
Almeida
Post by Almeida » Mon May 23, 2005 10:45 am
Ok! Ben
Acho que o software ajuda um pouco, mas não é muito confiável, pois quando calculamos uma potência de valor por exemplo 1,2Kg, as dimensões variam muito de um programa para outro.Estou me baseando em alguns artigos em pdf que possuo e alguns sites.
Obrigado pela tradução, meu inglês é meio fraco.
Estou pesquisando no comércio do país o material da válvula, mas está difícil, se alguém do fórum possuir ao menos um pedaço, que dê para montar ao menos uma válvula com 5cm de diâmetro, poderíamos negociar.Estou com o meu pulsojato já pronto, é meio rústico, estou ansioso para funcioná-lo, até montei uma válvula com aço normal, vou testar, acho que vai durar um segundo.
Aguardo se alguém tiver algum telefone aqui no Brasil, onde posso encontar o material!
Mathias
Post by Mathias » Mon May 23, 2005 4:19 pm
Bem , Almeida,
sou de Curitiba, também montei um pulso jato e para um começo utilizei aço SAE 1070, não aguenta mais que uma corrida, isso se não ocorrerem outros fatos!!!
Para este caso vc deve utilizar um aço com mais liga para aguentar temperaturas mais elevadas, agora, não saberia te indicar um local ai em SP onde adquirir!!!!
Mathias
Almeida
Post by Almeida » Mon May 23, 2005 4:39 pm
Ok! Mathias.
Eu encontrei o aço SAE 1095 temperado ao custo de R$ 480,00 o metro, caro mesmo, a firma chama-se StripSteel fica em SP.
Hoje vou ver com um conhecido que ele tem a maneira para temperar o aço comum para torná-lo mais resistente.Assim que eu fizer os testes eu dou resposta.
Obrigado!
