Help REALLY needed for REALLY insane project....
N_AVenger
Post by N_AVenger » Thu Apr 21, 2005 9:41 pm
Hello people..! I'm looking for some help - I and my friend are now working on our project - pulsejet-powered.. eh, how to call it? buggy? dragster? go-kart? i dont really know=) maybe i'll post here Rhinoceros models 4 you, but - the specs are:
aluminium frame - we bought nice aluminium pipes - 40mm in diameter, 1,5mm thick and 2 meters long
POWER - 2 50kg-thrust engines (this buggy-dragster-no-matter-how-to-call is for 2 person, and it has to carry really big amount of fuel, LPG)
We need help in designing reed valves that can last at least for an hour-1,5... we heard about Aeromarine 8 in. pulsejet's valves very long life - and maybe anyone of you, reading THIS has some good ideas for us?
re: Help REALLY needed for REALLY insane project....
Post by mk » Fri Apr 22, 2005 8:16 am
250kgf??? You're nuts, aren't you?
OK, rather go valveless for this size. Especially when running the engine for 1.5 hours.
BTW How many cub. m of fuel do you want to carry around?
I'd really suggest going for smaller sized engines and rather put three of them on your vehicle later on, instead of one "monster" that might shadder in pieces!
Post by Mike Everman » Fri Apr 22, 2005 5:16 pm
I think he means "two" 50 Kg engines. Still monsters, though.
N_AVenger
Post by N_AVenger » Fri Apr 22, 2005 6:06 pm
of course two 50kg! and, of course, monsters!=)
N_AVenger
Post by N_AVenger » Fri Apr 22, 2005 6:15 pm
And - if valveless- what design is preferrable?
We firstly decided valved cause we need max thrust and min "eating" of fuel... Hard task..=)
If anyone has any ideas, or even got some plans\blueprints, you can mail me: navenger@yandex.ru
Post by mk » Sat Apr 23, 2005 9:09 am
Ohhhh...OK, 50kgf sounds better. But, indeed, still monsters...
I don't know what you'd want to pay for plans or an engine or something, but if your budget is a bit above low-cost ask the GLC guys (Luc and Viv). They can Help you 100%-ly.
I don't know how much thrust this one delivers and how fuel guzzling it is. There also was a smaller Lockwood-Hiller Lift Reactor drawing somewhere. Its max. comb. chamber ID was 7".
Go to the valveless forum and ask/search there again. Good start is this topic.
Dave
Post by Dave » Mon Apr 25, 2005 11:54 pm
Marten
The engine in the first link you provided has a 14" combustion chamber. A minimum 6" exhaust at the elbow and a whopping 10.5) inches at the outlet! Is this the mythical 150 -200 pounder?
Dave
evildrome
Post by evildrome » Wed Apr 27, 2005 1:57 am
I don't think you can carry fuel for 1.5hrs operation of a 200lbs/ft engine.
Not propane at any rate. You'd need a tank the size of a bus. I'm not joking. My engine
http://www.wilsonlogan.com/Spulse-jet04.htm
doesn't even run properly & it consumes 2kgs propane / min. Thats 180kgs for 90 mins. You should think about gasoline or JP4 or diesel.
Cheers,
Wilson.
