Well, we got a need to create the cheapest attack drones, and the most mass-produced ones. We immediately discovered that a turbojet engine is too expensive for a large series, and it's impossible to find so much money, but with a piston engine the drone flies too slowly. In result, we decided to consider a pulsejet engine, according to the old German tradition.
Further, there will be a lot of words below, and we apologize in advance to all pulsejet specialists, but it is impossible to explain the problem briefly.
So, we started to figure out what's what, and almost immediately came to the conclusion that developing a project with a calculator, cutter and welding machines in own garage, that is, everything as you like here, is already a completely frivolous undertaking. At least, for our projects.
Then, we looked at what people do in terms of pulsejet calculations and modeling. It's a pitiful sight, if not to say horror. On the one hand, a bunch of scientists who write some murky programs just to write their clever articles only. On the other hand, some strange individuals who seemed to have done something, and even seemed good, but it's impossible to use and repeat it. Well, and the third ones have gone somewhere into the astral plane: they have taken up 3-D modeling for drawing very nice pictures. But it is completely unclear for what and where to do with all this, especially when for some reason they start modeling transverse vibrations of petals. And the most interesting thing is that no one has a hint of calculating thrust and fuel consumption, including by flight speed. Therefore, why they did all this remains a mystery to us. Of course, this is only our opinion, but it turned out that all these "achievements" are impossible to use in real practice, and accordingly, they are not worth a dime.
By the way, all this disgrace cannot be compared with the ideal order in turbojet and piston engines. There, you can buy or even just download free of charge 3-4 standard programs for each type, and they will not only model the entire work process for you, but also draw the engine itself, and then calculate all its characteristics. Nothing like this is even close to being observed for pulsejets, except for some murky calculators, because everybody knows pulsejet is extremely complicated thing, bla-bla-bla. Therefore, and everybody knows it still much better, the calculators are all that we can get. Unfortunately, they might be fine for own garage with cutters and welders, but we decided that we had slightly different goals and tasks. So we approached the matter from absolutely different side.
As a result, in a couple-triple of weeks we developed our own pulsejet mathematical model. Then, in a couple of months, we have moved further and already got a workable modeling program. For final debugging, it was posted on a specially created website, having developed an interface for the program.
This is our program, welcome!
The website has a fairly detailed description of how the mathematical model itself was made, and how the program works. Of course, this is only the beginning, we will continue to improve, deepen and add all this. But a certain fact can already be recorded: it seems, this is the first online program for calculating and modeling the pulsejet's working cycle, we have not found anything like this yet. And it is the exactly first such program, where it is possible to modeling both pulsejet engine types, valved and valveless.
The main features of the model and the program, briefly, so as not to take up the time of respected specialists in pulsejets, are the following:
1. Everything is online, for everyone. But there will be a special service for professionals.
2. You can simulate online the working cycle of all the main types of pulsejets - both valved and valveless.
3. The principle of the model and the program operation is in solving a large system of differential equations of the 1st and 2nd orders. Only the geometry is set, then, after the engine is started by supplying starting air, all the parameters are determined by the program itself. The program calculates the pulsating process in the engine, and these are cycles of self-oscillations of gas pressure, temperature and velocity, at the end of which the thrust, fuel consumption, and frequency are calculated. Moreover, if the engine has entered the self-oscillation mode, it is working, but if it cannot start and stalls, it is dead. You can check for yourself that this is never a calculator, which everyone likes so much
Main engine dimensions - it is possible to use default sizes or to write in the own ones
4. Combustion chamber: for now, it is assumed that the gas is distributed uniformly in a certain volume there, i.e. the instantaneous pressure and temperature in the chamber are the same by volume. At any given time. This allows using a 0-dimensional thermodynamic model to describe the processes of gas-air filling, mixing, combustion and leaking. The combustion process is described as in liquid rocket engines. It means how much air has entered at a given moment in time over a short period, so much fuel has burned, but after an ignition delay time. Then we will clarify and improve all this, if necessary.
5. For resonant pipes (in valveless engine for the intake pipe too) the so-called "liquid piston" analogy is adopted (this is not our idea, the University of Cincinnati likes it too, by the way). This is when the dynamics of the movement of a certain mass of gas concentrated in the middle of the gas column is calculated. The addition of cold air during reverse flow is taken into account, it is especially important for the intake pipe in a valveless engine. Then we will replace all this with a 1-dimensional model of gas flow in a pipe, as in ICE models, but for now the "liquid piston" is more than enough for everything. Well, and for now, the calculation is only for the cylindrical pipes, a conical one will be added later (not all the features at once, only gradually).
The features of valveless engine - all the default parameters can be changed on your own
6. The program allows you to assemble and test the engines of different designs. For example, it can be a valved one with front and side inlets, a valveless one with several intake pipes, etc.
7. The valves are available in different design and geometry options, including RC plane engine circular and "adult" wedge grids. The program calculates the petal movement optionally in a quasi-static version, when the valve opening depends only by the pressure drop, or by dynamic version: with lift delays, petal rebounds and gas backflows. The petal temperature will also be calculated, but later.
The valve system allows to consider many different types of valves
8. At the end of each cycle, the thrust, air, fuel consumption and frequency are calculated as integral parameters. The user can set any number of cycles up to 10, but as a rule, in a workable engine, the difference between cycles in % (we took it as a calculation error) after the 7th cycle is minimal.
This is picture, how does engine start and work
9. The program is designed so that the user can choose which engine he needs. There are 3 basic engine options: a small valveless, a small valved and a large valved type Argus 014. For each of them, default parameters are set, which can be changed within the specified limits or left as it is. This principle greatly simplifies and speeds up the data entry for modeling any engines.
10. For advanced users, there will be a special, not very heavily paid version - with its own account, recording of calculation data, downloading of the results, with parametric modeling and other useful features. But a little later.
Output of the main parameters
11. The mathematical model and the program never provide 100% accuracy for all engines. We don't even want to explain why. However, the approximation that already exists, sometimes even very rough, and the dependencies that are already obtained, have already proven useful in practice. For us, in general, this is enough. But we are open to those who are ready to help and improve the model and the program.
12. And one more important thing. This is not an "open source" at all, which everyone likes so much. On the contrary, everything is completely closed, and it's impossible to see model algorithm in the source code of the website. This is our know-how, which we now offer for use, and only in the form that we consider necessary. Free and for everyone. But only for now. It will definitely get worse later, because not for everyone and not for free.
So, the very first tests already gave us interesting results. It is especially interesting for the valveless: there the main thrust is created, it turns out, by the intake pipe, and not by a long resonant one, as everyone is always sure. In addition, the frequency of a valveless engine is always lower than that of a valved engine of the same basic dimensions. We really did not know this until the model showed it. The valved engine is also interesting: if you expand the valve grid too much to make the minimum possible resistance, the engine does not want to work at all, because there is nowhere for the vacuum in the combustion chamber to come from. But everyone always knew that the more is the better, right?
Diagrams of the last calculated cycle
But, of course, there may still be inaccuracies and failures in the model and program, including with some combinations of sizes. We will be glad if someone reports them. Of particular interest are specific complete data on all sizes of the completed engines and their real parameters (strictly according to the list of input-output parameters of the program), because this will allow us to refine the model. Gradually, we will bring it to a better condition and improve it, but not all at once.
In short, if you are interested, we invite you to first read about the model and the program on the website, and then try it.
https://pulsejet-sim.com
It is very simple, you don’t have to specify anything at all, you can just press the default data confirmation buttons, and one of the 3 selected engines will work at once! Even on your mobil phone too! Well, and please do not forget about comments and advice. Although the program already works for some practical tasks, it is still in the process of being finalized, so any information will be useful.
Thank you for reading to the end and hope all this will be useful.
