For sale: Coiled SS tube material, 45mm int. 49mm ext.
Anything you need or want to sell goes here.
Post by metiz » Fri Oct 02, 2009 9:07 am
For sale:
Coiled tube material as shown on the pictures.
Internal diameter = 45mm
External diameter = 49mm
The material is 304 Stainless Steel, 2mm wall thickness
The coil itself has a internal diameter of 380mm and externaly 478mm.
There are 4 complete turns on the coil and 2 half turns
Shown in the 1st picture are a single turn of the same coil material, A "U" bend and 2 90 degree bends. Please note that these components are made from the same coil you see in the other pictures. This means that both end are not lined up. Less so on the 90 degree bends of course. The 180 degree bend is slightly dented, as seen in the picture. The ends of the 180, 360 and 90 degree bends are not cut of at a perfect 90 degree angle so some work might be neccesairy.
Price
The 90 degree bends, Ill happily sell for €5
The 180 goes for €10
The 360 bend goes for €18
The coil is in good condition, I'd like €95 for that.
If you are interested or have any questions, please reply to this thread, email me at: Metiz(at)walla(dot)com or PM me.
