what you guys think this engine
, which is powered by a tiny pulsed jet and a very powerful sound system, the blades are powered by the negative and positive fields, the blades are levitated within millimeters of the magnetic field, there is only highly compressional blades located in the middle which act on each other by the magnetic fields powered by the incoming airflow we use sound waves to push high amounts of distributive air flow inside the chamber where the blades that are rotating and keep the rotating speed content with little help from the pulsed jet .
what you guys think ?
full picture
http://i51.tinypic.com/5cypzb.png
