Pressure Gain Combustion (Now Proven)
Post by Viv » Mon Dec 22, 2008 2:21 am
There is a point in adding turbo chargers to a piston engine were the piston engine ceases to be the prime mover and becomes little more that a gas producer for the turbines.
Not to far to go by the looks of it ;-)
http://v8tvshow.com/forum/index.php?topic=254.msg990
Hat tip to V8tvshow.com
No. 44
Re: Pressure Gain Combustion (Now Proven)
Post by No. 44 » Mon Dec 22, 2008 6:28 am
That's just insane. Why not just use a purpose built turbine engine? There were a few proposed showroom models that would have run on a turbine instead of pistons and they do superior power and speed but at the rate they guzzle gas you're either not going far or you'll need deep pockets because of how much you'll have to fill up.
Still, this looks absolutely kick-ass!
Post by Viv » Tue Dec 23, 2008 3:08 pm
No. 44 wrote:That's just insane. Why not just use a purpose built turbine engine? There were a few proposed showroom models that would have run on a turbine instead of pistons and they do superior power and speed but at the rate they guzzle gas you're either not going far or you'll need deep pockets because of how much you'll have to fill up.
Well its a piston engine race class so a full turbine is out of class and not allowed ;-) 2800 horse power takes a bit of fuel to produce but it only has to drive 1/4 of a mile at a time ;-)
