Ok, that's not a jet vehicle but it will go like it has a jet!
Through a friend who has to install ultracapacitors for a project at work, I stumbled on the data of these ultracapacitors:
http://www.maxwell.com/pdf/uc/Maxwell_UC_comparison.pdf
Look at the last unit. This is a unit in which a lot of capacitors are combined. During 1 second it can deliver 3930 amps at 125, let's say 100, volts!!
That is around 400 kW (=510 hp) for one second , out of 58 kgs (120 lbs). Combine a few and you have enough power to make a 1/4 mile run.
The only problem I foresaw was the huge size and weight of the electric motor, till I found this thread :
viewtopic.php?f=2&t=5467#p65209
Haha! ultralight high-power electric motors!! Thanks Axel for sharing the existence
Would like to make this a project but I already have a million projects
Fedde
Electric dragster
Electric dragster
Re: Electric dragster
You sure could have fun with a pair of those!
/Axel
/Axel
