PREDATOR - valveless PDE build blog
Re: PREDATOR - valveless PDE build blog
Post by Viv » Mon Jun 13, 2011 1:53 pm
Very impressive work, well done
zono
Post by zono » Mon Jun 13, 2011 2:13 pm
thanks, Viv !
Next time I will add some effects to visualize the run parameters. First show effect will visualize the exhaust impulse (damage of a sheet of paper, push-away a paper bin....) . For measurements I will construct a impulse-pendulum to indicate the impulse ( impulse conservation law : m1 v1 = m2 v2) to confirm 1800 m/s exhaust velocity (or whatever it indicates).
Next step is an improved injection and ignition control by Atmega169. Programming is done already, but my #@!?*$&§ Power-Mosfets do need 15V gate voltage, and the Atmega only provides 3,3V. ...Looking for a 15V line buffer (line driver).
zono
___________________________
zono - the thruster buster
Post by Viv » Mon Jun 13, 2011 2:20 pm
Hi Zono.
Ok That's all good, for the Mosfets you can try a standard opto-isolator, that will keep your logic devices safe on one side and you can simply power the other side with what ever gate voltage you want.
Pendulum thrust stands are a good choice but watch how you read it and calculate your results, it can be tricky to get a truthful reading as others have demonstrated in the past.
As I said good work, I enjoyed following your test
Post by metiz » Mon Jun 13, 2011 2:51 pm
Guess I have to eat my hat :D realy nice work!
With the right software and hardware in place, what kind of detonation frequency do you hope to achieve?
zono
Post by zono » Mon Jun 13, 2011 3:08 pm
@metiz:
I think 1...2 Hz. Filling is the bottleneck.
@Viv:
thanks, opto-coupling is expensive, but you are right! Best for safety.
zono
Post by PyroJoe » Mon Jun 13, 2011 3:30 pm
Good work!
Nice to see one put together.
Post by Viv » Mon Jun 13, 2011 4:52 pm
zono wrote:@metiz:
@Viv:
zono
Hi Zono
Sorry expensive? are talking about the same thing, should be cheap as chips.
http://en.wikipedia.org/wiki/Opto-isolator
http://www.electronicrepairguide.com/optocoupler.html
zono
Post by zono » Tue Jun 14, 2011 6:03 pm
hmmm right Viv, I found some opto for less than 1$ .....lets try transistor-optos and triac-optos
zono
Post by Viv » Tue Jun 14, 2011 6:21 pm
zono wrote:hmmm right Viv, I found some opto for less than 1$ .....lets try transistor-optos and triac-optos
zono
Hi Zono
Keep it simple and go for the transistor ones as it will be easier for you to interface than the triac versions (better for high power operation in PSU)
zono
Post by zono » Wed Jun 15, 2011 10:28 pm
See some details of the test rig:
spark plug, gas injector and solenoid valve
zono
zono
new run in2012 PREDATOR - valveless PDE build blog
Post by zono » Fri Jun 08, 2012 10:38 pm
Hi friends,
new runs of Predator were done on DOT (Days of speed and Thunder, big pulsejet meeting in Rothenburg, Germany at 17.-19. May 2012, http://www.pulsotriebwerk.de).
As announced before, I tested MCU controlled gas injection and ignition - with great success!
Now I am posting the first images. More come in the next days...
PS: the supports were rammed into the soil due to the detonation impulses
zono
Post by zono » Sat Jun 09, 2012 10:02 pm
and here are the vids:
http://www.youtube.com/watch?v=Nn9I1RXT0TM&feature=plcp
http://www.youtube.com/watch?v=TYLmpxKcnDM&feature=plcp
Detonation shockwaves had awsome intensity. They destroyed parts of my test rig (momentum gauge)
zono
Post by zono » Sun Jun 24, 2012 4:00 pm
hmmmm
nobody left in the PDE forum? Nobody interested any more? Not even defense industry ;-)
have a look above. New runs done in May 2012.
Post by metiz » Sun Jun 24, 2012 6:57 pm
Will your engines ever be able to run continiously?
Post by Mike Everman » Mon Jun 25, 2012 2:08 pm
Oh, definitely still interested!
