Shchelkin spiral
Pieter van Boven
Shchelkin spiral
Post by Pieter van Boven » Mon Aug 29, 2005 9:37 pm
Hi everybody!
Would it be possible to make a Shchelkin spiral? After some reading about PDE's it is clear to me that you must have such a device to built a liquid fueled air breathing PDE. ...and most of us here like building...
who knows more about it and would it be possible? This is what I found so far:
http://www.usc.edu/dept/ee/Gundersen/ig ... AA2005.pdf
Pieter.
re: Shchelkin spiral
Post by Viv » Mon Aug 29, 2005 10:01 pm
This is the ripple in the wall of a 12.5mm thick steel tube as a PDE fires!
It is exagerated a bit for clarity but it is accurate, this ripple is caused by the combustion pressure wave.
So before you start thinking about building a PDE start thinking about the engineering involved:-)
Its a bit higher duty than sheet steel pulse jets thats for sure:-)
Post by Viv » Mon Aug 29, 2005 10:02 pm
I thought this double posting thing was bad luck but there seems to be a server problem with the host, it loses communication during the post upload
