Linux glitches
WebPilot
Re: Linux glitches
Post by WebPilot » Fri Apr 16, 2010 3:56 am
 All said, Firefox is "buggy" in Ubuntu. It does act up from time to time.
WebPilot
Re: Linux glitches
Post by WebPilot » Sat Apr 17, 2010 3:03 am
 $ uptime
 21:25:34 up 15 days, 8:39, 17 users, load average: 1.44, 1.19, 0.88
WebPilot
Re: Linux glitches
Post by WebPilot » Mon Apr 19, 2010 9:33 pm
 $ uptime
 19:19:04 up 18 days, 6:33, 18 users, load average: 0.74, 1.02, 1.10
WebPilot
Re: Linux glitches
Post by WebPilot » Tue Apr 20, 2010 1:11 am
This is NOT a glitch.
WebPilot
Re: Linux glitches
Post by WebPilot » Tue Apr 27, 2010 5:23 pm
 I came home today to a house where the microwave display was blinking (no time display) and the 110v electric clock was 1 hr behind - major household electrical power failure!
WebPilot
Re: Linux glitches
Post by WebPilot » Wed Apr 28, 2010 2:46 am
 I had left my computer "on". It has an SPS attached to it, but I believe it will only supply power for about 1/2 an hour. The screen was dim with an orange asterisk on the display. When I pressed the spacebar, the screen 'lit" and I was in a console session with error messages.
 When house power was restored, my machine could not successfully reboot unattended.
WebPilot
Re: Linux glitches
Post by WebPilot » Wed Apr 28, 2010 3:09 pm
The error message on the screen was
the fsck should be performed in maintenance mode with the root filesystem mounted in read only mode (root filesystem is currently mounted in read only mode)
WebPilot
Re: Linux glitches
Post by WebPilot » Thu Apr 29, 2010 2:54 pm
 I'll return to how I fixed this problem.
 Kernel upgrade today. Rebooted with no probs.
WebPilot
Re: Linux glitches
Post by WebPilot » Fri Apr 30, 2010 12:23 am
 I spent a bit of time trying to get this Calligra font to work. I finally had to compile and install it manually. Running mktexlsr remedied the final "glitch".
WebPilot
Re: Linux glitches
Post by WebPilot » Tue May 04, 2010 1:14 am
WebPilot wrote:The error message on the screen was
 Since the root filesystem was already mounted in read only mode ...
WebPilot
Re: Linux glitches
Post by WebPilot » Tue May 04, 2010 2:53 am
 At the prompt in the text window I logged in as root and ran the command,
Code: Select all
:~#  fschk
     fschk ...
     e2fschk ...
    /dev/sda3 contains a file system with errors, check forced
     Pass1: checking inodes, blocks and sizes
     Pass2: checking directory stroucdture
     INVALID HTREEE directory inode 1 392 897 (~/.thumbnails/normal)
    Clear HTREE indes <y>? yes
    Pass3: checking directory connectibity
    Pass3A: optimizing directories
    Pass4: checking reference counts
    Pass5: checking group summary information
    /dev/sda3: ***** FILE SYSTEM WAS MODIFIED *****
    /dev/sda3: ***** REBOOT LINUX *****
    /dev/sda3 557.../564... files (5.2% non-contiguaous), 210 ... /225 ... blocks
:~#  Ctrl-D
WebPilot
Re: Linux glitches
Post by WebPilot » Thu May 06, 2010 5:04 pm
 The machine rebooted successfully and has been running "just fine" ever since.
WebPilot
Re: Linux glitches
Post by WebPilot » Mon May 10, 2010 1:02 pm
 This is not a glitch that exists solely with Linux.
 You may have noticed the new Google search interface, which features a new left-hand navigation (left sidebar) and a modified Google logo which looks pretty cool. The new side panel highlights the most relevant search tools and refinements for your query, making it easier to find exactly what you’re looking for.
WebPilot
Re: Linux glitches
Post by WebPilot » Wed May 12, 2010 3:05 am
 I find it annoying.
 Previously, deleting this cookie was enough to disable it.
 ... this no longer works.
WebPilot
Re: Linux glitches
Post by WebPilot » Fri May 14, 2010 2:06 am
 So, I looked for another solution.
