youtube
Re: youtube
Post by Mark » Tue Sep 26, 2017 4:03 pm
Yet another ...
Manned Octacopter
https://gfycat.com/BrownParallelCaribou
Re: youtube
Post by Mark » Thu Sep 28, 2017 11:24 pm
Re: youtube
Post by Mark » Tue Oct 17, 2017 2:34 am
Tealight Pulse Jet
"I honestly have no idea how I made this. I was just experimenting around with empty tealights and pure ethanol and suddenly it started pulsing."
https://www.youtube.com/watch?v=HxsJna3tMF4
Re: youtube
Post by Mark » Wed Nov 01, 2017 12:46 am
A pulse jet with a jam jar jet exhaust port
自作小型パルスジェットエンジンで風車回し2 pulse jet engine
https://www.youtube.com/watch?v=rnqfKCuFrss
https://www.youtube.com/watch?v=sBaAxmueDLM
Jam jar jet boat
https://www.youtube.com/watch?v=MKMab6pJwas
Re: youtube
Post by Mark » Wed Nov 01, 2017 1:10 am
"It is a compact, pulse jet using a drug bottle. A hole of 6 mm is drilled in the lid of the bottle."
Bottle pulse jet
https://www.youtube.com/watch?v=RD9tMbgvfn8
Not a bad demo
https://www.youtube.com/watch?v=JkWpQRS3vkY
Glass tube putt-putt boat.
https://www.youtube.com/watch?v=JokZp3zXhEU#t=1m17s
Re: youtube
Post by Mike Everman » Wed Nov 01, 2017 4:49 am
I want to make a big putt-putt boat. have a meet and do races or something
Re: youtube
Post by Mark » Wed Nov 01, 2017 2:26 pm
Putt-putt boats would be more auditory friendly.
Re: youtube
Post by Mark » Fri Nov 03, 2017 12:59 pm
Tidbits from 2005 - Just old stuff
"You can also use a single piece of copper tubing with one end pinched closed. This might be thought of as a "half" of a typical putt putt engine. A fellow I conversed with was using such an apparatus to propel his canoe along a river. Not really the most efficient way to use heat but it worked. In a vague way, my piglet snorkeler is "half" of a typical valveless pulsejet."
And this I dug up from the Pop-pop page references. It might be funny to brightly colorize a man-sized putt-putt boat in keeping with the miniature putt-putt boat motif. ha
Man-sized engine and stuff ...
"This paper is concerned with a remarkable fluid flow phenomenon which should
logically be called "the McHugh effect," or "McHugh cycle" after its discoverer,
C.J. McHugh In its original form (Figure 1), it was clearly the
(mechanically) simplest heat engine ever invented. When heat is applied
to the boiler, the water column in the tube oscillates backward and forward
and the toy boat is driven forward through the water."
http://www.dtic.mil/dtic/tr/fulltext/u2/a046533.pdf
1915 McHugh Patent
http://pdfpiw.uspto.gov/.piw?PageNum=0& ... C200%2C960
http://www.nmia.com/~vrbass/pop-pop/
Re: youtube
Post by Mark » Sun Nov 05, 2017 3:16 am
How Heat-Resistant (Borosilicate) Glassware Is Manufactured
https://www.youtube.com/watch?v=PWdvQIBAzhk
Re: youtube
Post by Mark » Tue Nov 07, 2017 8:11 pm
The Lava Lamps That Help Keep The Internet Secure
https://www.youtube.com/watch?v=1cUUfMeOijg
Re: youtube
Post by Mark » Fri Nov 17, 2017 8:46 am
Re: youtube
Post by Mark » Fri Dec 01, 2017 4:14 pm
Inflating Evacuation Slides
https://www.youtube.com/watch?v=nM8P6TtcrFY
This entraining aspect made me think of the Gluhareff pressure jet to some extent.
"Slides inflate with an initial boost from a canister of compressed carbon dioxide and nitrogen. The canister provides only about one-third the volume needed to inflate the slides. The remaining volume is supplied by ambient air, channeled into the slides through aspirators."
"When the inflation mechanism is triggered—by a lanyard pulled by the slide as it tumbles from its storage case—gas from the canister accelerates through the aspirators at high speed, creating a vacuum that sucks ambient air into the aspirators through louvers. When the slide is fully inflated, the louvers close."
Read more at http://www.airspacemag.com/flight-today ... 51CHQYT.99
Re: youtube
Post by tufty » Sat Dec 16, 2017 3:47 pm
You can do better than this, Mark
https://www.youtube.com/watch?v=FEOEyDRzkNE
Re: youtube
Post by Mark » Sun Dec 17, 2017 10:49 pm
I recall probably several years ago pondering that swan vase/decanter he tried, wondering if something like that might be fun to tinker with. Here he has an illustrative demonstration of using too thin of glass. It was fortuitous he was looking toward the camera when it gave way.
Model Rocket Engine Vacuum Tube Explosion
https://www.youtube.com/watch?v=QvHQpWNLTSo
Re: youtube
Post by Mark » Wed Dec 20, 2017 2:35 pm
3D-printed objects fit perfectly together
https://gfycat.com/AbsoluteEsteemedBasil
The Tallest & Tiniest Twist Containers Ever!
https://www.youtube.com/watch?v=zeK5XfstMLU
