Darn Good Historical Fun
Hey guys!
Just thought I would let you all know what combustion-related hobby has been occupying the time I formerly devoted to pulsejets ... shooting flintlock rifles! Flintlock rifles are great fun, powerful, accurate, and in Canada and the USA, completely unregulated. Black powder (the 'original' gunpowder) is hard to find but easy to buy (practically unregulated) in 'household' quantities. I bought a 25 lb. case of Goex in the spring from the one guy in 'eastern" Canada:
http://www.goexpowder.com/distributors.html
A one-pound can generally costs about $15 US and will supply about 100-130 shots. Black powder cannot be shipped in the mail. Some couriers will carry it for you but they charge a premium because it is classified as an explosive. Here is my reproduction .54 calibre Mortimer rifle by Davide-Pedersoli:
http://www.davide-pedersoli.com/img/Arms/S.240.jpg
It has a slow twist barrel for shooting patched round balls. I just recently bought another flintlock, this one by Austin & Halleck. It has a faster-twist barrel for shooting heavier conical-type projectiles and is .50 cal:
http://www.austinhalleck.com/images/mtnfs.jpg
Flintlock rifles, along with the balls, bullets and other accessories are easily purchased online and mailed back and forth between Canada and the USA. I got one of my guns from these guys:
http://www.trackofthewolf.com/
Flintlocks can be very reliable firearms and are accurate and deadly out to 100 yards and beyond. I can reliably fire both my guns 15 or 20 times before I have to clean the accumulated crud in the barrel, then they can be fired as many times again with no problems. It usually takes me about 2 minutes to re-load, aim, and fire but if I really push myself I can get an offhand shot off in just under a minute. It is interesting that the flintlock was by far the most popular firing mechanism for hand-held guns for over 200 years until percussion caps took over for about 40 years and then finally modern centrefire and rimfire cartridges were invented in the 1870s and 80s and have been the standard ever since.
Trig IS fun.
re: Darn Good Historical Fun
Hello Mike -- Welcome back!
Best regards,
M.
PS: I miss Tundra Man... =)
Did you sell the engine, or have you made any further progress with it?Mike Kirney wrote:The Skinner engine is just too big for me to run economically right now.
I would need a long-term capital plan to make it worthwhile...
Best regards,
M.
Last edited by milisavljevic on Wed Dec 06, 2006 6:31 am, edited 2 times in total.
avast!
Cap'n M.
avast!
Cap'n M.
TUNDRA-MAN!
Hey, cool. Not much in to guns, but had to say HI. Ever get that big steam engine running? I was hoping you weren't gone as a result of making a 10 foot diameter jam jar...
Thanks for the warm greetings, guys. I bought some steel pipe and fittings to make a water-tube boiler for my steam engine. I am probably going to build something in the spring.[/img]
- (89.27 KiB) Downloaded 502 times
- AUT_1061.JPG (98.76 KiB) Viewed 5970 times
Trig IS fun.
Here I am target shooting ...
Trig IS fun.
Cracka-boom!
See Mike, flintlocks are great fun! Shooting them is sort of like shooting pool. You dial in your load, line up your shot, take a breath and shoot. If you worked everything out correctly, you will hit your target. The whole process takes about five minutes. Flintlocks are particularly fussy firarms, but once you have the wrinkles worked out (powder charge, patch thickness, ball diameter, etc.) they are great shooters. Humid days can be a problem because the black powder is very hygroscopic. Cold days are good because the air is usually very dry, unless the temperature is near the freezing/melting point. I had a better clip of the full loading sequence followed by an embarrasing misfire but it was too big to post here. I have a clip from the summertime posted on MySpace:
http://www.myspace.com/mikekirney
Trig IS fun.
Old ways
Hi Tundra from Spanish Moss. I guess this archaeological/historical post could/should go here with your flintlocks.
http://www.theonion.com/content/node/48970
http://www.theonion.com/content/node/48944
"This clearly points to a reverence for the technology, but also an intense anxiety about a power they could not have understood,"
"Listening to the whir of the disc drive and watching the blink of the cursor, we glimpsed, for a moment, life through a completely different set of eyes," Caspari said. "But, in the end, we realized have more in common with our shadowy ancestors than we might like to think."
The first cars
