Eric, I still like this design and regret the fact that (to the best of my knowledge) no one has tried it.Eric wrote: everyone though the valves would have to travel too far but didnt seem to pick up on the fact that if they were made V shaped the internal resistance and travel distance is greatly reduced.
What I find very interesting is that this thing will not move the flaps in quite the same way as, say, a Dynajet. The V-shaped valve flap will be both pushed by the hot gas pressure and pulled by the vacuum. Normal reeds are pulled by the vacuum to open and pushed by the hot gas to close. (This is not quite true, but good enough for the purpose of explanation.)
So, the dynamics will be different. Its surface area will be greater than in a conventional engine for a given engine section. Aerodynamic drag of the flap will be massively lower than in the reed valve assembly. The inevitably lower working frequency will be more than offset by the fact that the useful frequency will be double, because of two combustors working out of phase.
Practically the only thing that bothers me is the symmetrical working cycle.
Warning! Warning! A major boast follows!
Let me say here that I think I have discovered why paired identical combustors develop less than double the thrust of a single combustor. (That much was established by the Kentfield team in Calgary – the only people I know of who have done extensive work on pairing combustors.) Conventional theory said that they should aid each other and thus develop more than double -- but in practice, the combined thrust was a bit lower than double. The reason has been a complete mystery to everyone – including Kentfield, who expected a gain in performance.
I’ve been chewing on that for years without becoming any wiser -- and then it finally dawned on me.
As always, the answer is amazingly simple. The secret is that with synchronized work, the working cycle is symmetrical. The intake must last exactly as long as the exhaust or the combustors will not be in sync. This is not good! In single operation, you try to time the intake phase to last quite a bit longer than the exhaust. If you restrict the intake to just a half of the cycle, performance will suffer.
